change Lattice object?
Message 1 of 8
Hi, I've recently been experimenting with the lattice modifier and was curious if there's a way to input a custom object over the default joint options (Tetra,octa,icosa). i.e. placing a teapot on each of the vertices that inherits the colour/texture of the plane.
Replies (7)
Message 2 of 8
rendermaster
not possible
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 8
Would there be an alternate method to achieve this i.e. creating it in particle viewer to achieve similar outcome?
Message 4 of 8
rendermaster
you can use SUBSTITUTE MODIFIER too..check this.
Message 5 of 8
Thanks very much for that @rendermaster , on a slightly different note do you think it would be possible to transfer this kind of mapping method to spotlights?
i.e. I essentially want to have a series of spotlights that change colour based on video, is there a way you can change their input colour based on mapping?  desired result below
Thanks again for your help
Message 6 of 8
rendermaster
not sure if this is what you want, check this:
Message 7 of 8
@rendermaster No it's not necessarily a single light projection of 1 image, rather each spotlight acting as a pixel on a low res screen.
Somehow the spotlight would change it's RGB value based on the pixel it's trying to represent.
Message 8 of 8
hagen.deloss
@Anonymous
The two most straightforward ways I would think to do this is either with a self illumination map, or just hand keyframe the lights color to change.
You may be able to get a similar effect by parented lights to turn on and off depending on different colored objects...
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
