Announcements
Certain textures/materials/objects not rendering
png24
png24
I'm super new to 3DS max and I apologise if this is the wrong place to ask this. I'm currently trying to make a little race track map for a university assignment, but when I try to render it it doesn't show the textures of the mountain (that I drew with the viewport canvas) or the orange line in the middle of the road.
Attached is an image of the map in the viewport in DX mode (for some reason the orange line is black in standard mode) and a screenshot of the render.
Thank you in advance and sorry if this is a dumb question!
CiroCardoso3v
Which renderer are you using? Could be that the material you are using is supported in the viewport, but not by the renderer.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
raiden_xavier
Autodesk Support
Autodesk Support
Hi @png24,
Thanks for sharing your issue with us.
Did you see the message from @CiroCardoso3v?
It may help us if you could share a sample scene so we can inspect your material editor and render settings.
Use the Archive feature to zip up the scene.
If it cannot be shared on the forum you can send it to me in a private message.
We look forward to hearing from you.
Many thanks.
png24
I changed the material type and changed my renderer to Quicksilver Hardware Renderer and it worked! Thank you!
png24
CiroCardoso3v's solution did help, thank you for your time!
CiroCardoso3v
You are welcome. Happy to help.
Ciro Cardoso
