Cant move or delete faces in 3ds Max 2019
Having similar issues. Can't delete objects or faces on objects in my scene. 3ds Max 2019. Restarting isn't fixing it.
Have installed the security patch provided by Autodesk linked above. Installed, nothing changed.
Ran the checker in MaxScript Listener - returned False.
Your post has been turned into a thread by @hagen.deloss
Original thread can be found here.
hagen.deloss
Hi @Anonymous
Thanks for bringing this issue to the forums! I'm curious, have you tried opening a blank scene, navigating to File > Merge and see if you can then select objects within the scene?
Is this the case for newly created objects within the same scene?
If you can provide a file with this issue, i would love to test things on my end 😄
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
hagen.deloss
@Anonymous
Any ideas or questions on my previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
