Can't Modify Objects In A Group
jordanAFTS
jordanAFTS
New to 3DS Max, so this might be a D'oh! moment. I have a DL'ed model and I can't ungroup the objects. They all seem to be on child layers from a parent layer (Layer 0). I can turn them off, but when I assign a material to one, it changes the entire group. This is what I'm getting when I select any of the layers:
Any help is very much appreciated.
PROH
Hi. Go to the "Group" tab (top bar menu) and select "Open". Now you should be able to select and modify each object in the group. After you're done, you can close the group again.
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
jordanAFTS
Hope it helps
Thank you so much! That was pretty darned simple. I have so much to learn with this software.
