Cannot import or link Revit file into 3ds Max. Error 81
CarolKostandy
CarolKostandy
I have Revit 2023 and 3Ds Max 2023, both worked completely fine a week ago. I tried linking a newer revit model into 3ds max, but it showed an error, "importing Revit files is currently unavailable, please try again later. error 81". It worked fine before, but now I cannot import or link any revit files.
rendermaster
Download / Install / Upgrade Revit Interoperability
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
CarolKostandy
I tried reinstalling both Revit and 3Ds Max, nothing works
mromagnoli
Dear @CarolKostandy
The problem is fixed with the following plugin AdODIS-installer.exe
I share this video so you check that the error is resolved simply by installing this plugin.
https://autode.sk/3z7MRg2
you can download it from here - https://www.mediafire.com/file/ke1s7gbw7umsdhp/AdODIS-installer.exe/file
Try it
Luck! 😉
Arq. Marco Romagnoli
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
obada302
Community Visitor
Community Visitor
Hello my friend ..
have you found any solutions for this problem (error 81) ? because I have the exact same issue in 3ds max 2024.
