Can't see the gizmo in edit mode
Message 1 of 18
I can't see the transform gizmo and I cannot transform in edit mode and am at a complete standstill.    I can see the axes.Screenshot_1.png
Replies (17)
Message 2 of 18
irishman_team_kilber
hit the X button
Message 3 of 18
When I hit the x button it says "Search all actions."  Autodesk 2018.
Message 4 of 18
planner_matlabi
hi
2016 version and upper version = Shift+ctrl+X
Or
Start appliction > Option > Gizmo Tap > Mark ON GIZMO Trans
Message 5 of 18
Shift+Ctrl+X does nothing in edit mode, only in object mode.
"Start appliction > Option > Gizmo Tap > Mark ON GIZMO Trans"
I don't understand.  Where is Option? It is not a tab.
Message 6 of 18
The X button will hide and unhide the gizmo ok try and hit the shift  control and the x
annoying link https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
Message 7 of 18
planner_matlabi
I am Send Picture For You
Message 8 of 18
Gizmo is already enabled.
Message 9 of 18
Does this pink box have anything to do with my problem?
Message 10 of 18
No, I closed the box and nothing changed.
Message 11 of 18
No it's just grouped, are you sure you have not use the - sign to make the gizmo smaller it try making it bigger by keep hitting the + sign, if that doesn't work then you mite need to Reset 3ds Max / 3ds Max Design to default user profile settings https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Resett...
Message 12 of 18
I reset my settings and I still cannot edit my mesh.
Message 13 of 18
did you get your gizmo back?
why do you have 2 mesh selects on one mesh?
Message 14 of 18
The transform tools are disabled.
Message 15 of 18
Does it have to do with the polar array and history?
Message 16 of 18
your tranforms are unavailable because your in sub-object model if you want to edit your mesh then you can convert it down to a edible mesh or poly or add a edit poly or edit mesh modifer
Message 17 of 18
Thank you! I was using the Mesh Select modifier not the Mesh Edit modifier.
Message 18 of 18
Autodesk doesn't want you to change the shortcuts. Suddenly, the gizmo was locked and panicked in the midst of a busy situation, but even the shortcut keys were changed, so I was very troubled and really upset.
