Can I save out and re use the batch render set up?
tim.atkinsonNHY4C
tim.atkinsonNHY4C
Hi folks,
My master max scene has unfortunately stopped working for me, i can re build this easily by merging in lights, and adding my X-Refs, however i have set up quite a few outputs from the batch render dialogue. I can still open the old file, but it gives me an unhandled exception when i try to render. (Vray)
Is there any way I can access the batch render set up and port to my new scene?
Thanks for any assistance
spacefrog_
Just checked myself as i was'nt sure, but seems the merge dialog option/checkbox to merge the "render settings" does indeed not merge the batch render settings
Seems the only way to dublicate the batch render settings would be a small maxscript that would query and store the batch render views from the original scene and regenerates them in the new scene
depends on the setup complexity whether this is worth the effort or the batch render setup simply be recereated by hand ( sadly you can't import the exported batch file neither )
Josef Wienerroither
Software Developer & 3d Artist Hybrid
