Hi group,
In this dron video,
It has been very difficult for me to place the coordinate system that fits the design perfectly.
I'm using Matchmover, I want to use a few points with their real coordinates so that the process is fast, do you know how to do it?
Now I have seen that they use Affter efect, but I do not know if you can place the 3D design in real coordinates in the video.
What is the best workflow?
Thank in advance
Regards
maybe you use the camera tracker Utility? https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/3DSMa...
or maybe the Camera Tracker: Motion Trackers Rollout https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/3DSMa...
Thank irishman,
I've used it before, I thought MatchMover was easier.
But I will try here in 3ds Max
Regards
In MatchMover it is very easy, creating the coordinate system is perfect.
Regards
