Please, i need someone to help mo to conver this save file from 3ds max 2019 to 2018. because i cant open it on my laptop, i have the 2018 edition.
Thanks for the help every one. really need it.
Solved by RobH2. Go to Solution.
Let me see if I can help you. I first need to scan the file to make sure it has no virus.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------See if this works.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Glad to help. Welcome to this great forum. Take advantage of the great artists here.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Hi sir, i really need someone to help to convert this save file from 3ds max 2019 to 2018. I can;t open in it with the current version i am using (2018)
Try this.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Mr Rob, I would like to thank you very much. You are a live saver! I'm sorry to troublesome you, but it would mean alot if you could help me convert two more files. If you're busy, I understand. Again, Thanks alot for your help.
