[Bug] Build Corner doesn't work in Edit Poly
There is a weird bug in the Build tool.
Using Build End on Editable Poly works as intended:
Using Build End on Edit Poly Modifier works as intended:
Using Build Corner on Editable Poly works as intended:
Using Build Corner on Edit Poly Modifier does nothing:
Correct. This is a bug that never got fixed.
ads_bunescc
Hi @Anonymous ,
Thank you for posting your finding. I was able to repro on my side and I send it to the development team for futher investigation.
Thank you,
Catalin
QA-3dsMax
