Hi, I have Installed 3ds max 2017 recently. After using it for a day or two. I am suddenly facing a UI problem which is interfering my work. I cannot see texts and units properly. I went through UI settings but can't find anything good to fix this issue.
I have added a image of it.please have a look. I'll be really grateful If you could help me with fixing this issue
Solved by DanielCantin. Go to Solution.
Hi @Anonymous
Welcome on the forum and thanks for reaching us.
Can you try Resetting 3ds Max to default user profile settings, that is usually the first thing to try as corruption of the user profile is not uncommon.
Please let us know if this fix or not your issue and if it does, accept as solution, thanks.
Hello @Anonymous
I wanted to check in and see if @DanielCantin's suggestion helped resolve this issue?
It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
