Binding Editable Poly’s Bridge action to a hotkey
Message 1 of 22
It appears that the Editable Poly's Bridge action does not work from a bound key. I have bound the Bridge action to a hot key in both 32-bit and 64-bit versions of 3ds Max 2010, neither hot keys would fire off the Bridge action.
Bridging two edges of an editable poly object with a polygon does work when using the button in the editable poly's interface. Nothing in the Max Help documentation points to any reason why the Bridge action will not work when bound to a hot key.
Has anyone seen any issues with actions bound to hot keys not working?
Accepted solutions (3)
Replies (21)
Message 21 of 22
this is not a solution.
this is a workaround.
Message 22 of 22
deftrax
Man! Thats what I needed! Works fine. Thank you!
