Hello everyone, I am running Windows 10 and with 3ds Max 2016.I am getting a error now that says "Bad Image Error." C:\\Windows\SYSTEM32\VCOMP110.DLL is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support . Error status 0xc000012f. Any help would be appreciated .
Thank you !
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @Anonymous and welcome to the community!
I'd like to help you with this issue. I've seen this once before in another thread, here. Can you please let me know if that works for you? Thank you very much for doing so.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
