Any way to add the UVW Remove - Materials to a quad? If not, how can i attach a object maintaining only the main object material?
matheuspalmd
matheuspalmd
How to add that button (see below) to a quad menu? And how can i discover what is the group/category of any command? Is there a list?
Also, let's say i have object A (main) and object B. Both have materials assigned to them. How can i attach B to A but maintaining material A? When i attach the "Attach Options" dialog opens up but none of the options seems to do what i want.
I often have to use the remove materials button because after the work is done and i want to clean the scene there will be leftovers because now object A+B has a multimaterial, and even if i delete the B part, it is still in the scene.
matheuspalmd
Forgot to mention, i'm using Max 24
MartinBeh
Removing a material from the current selection, using MAXScript, is as simple as
$.material = undefined
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
matheuspalmd
Ok but is there a way to place it into the quad menu? Because making it a button is kinda pointless
MartinBeh
You can wrap that single line into a macroscript - which then can be used as a button, a hotkey, a quad menu entry, a main menu entry...
macroScript clearMaterial
category:"MB Tools"
   if selection.count > 0 then selection.material = undefined
Run this code, then look in the Customize > Customize UI (or > Menu editor) dialog for the action "clearMaterial" in the category "MB Tools"
