3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Animation Problem
3 REPLIES 3
187 Views, 3 Replies
Animation Problem
I'm having trouble with using the animation. I am trying to get a material to scroll at a constant speed, but when i try to change it so it will stay that way, i get an out speed of .333 on my first key point and an in speed of .333 on my last point. I try to change them but they are locked and it will not let me change the values. Is there a setting i may have on that does not allow custom values?
3 REPLIES 3
go to track view , search the Medit(or the object with that mat aplied) and change the animated parameter curve to linear since default is beizer.
That didn't seem to work. I can almost do what i want by making more points though but that really bugs me. I tried that but it still seems to like to slow down and speed up near the points.
Tim_Wilbers
What does the Curve Editor look like?
For constant speed you need to set the In-Out interpolation to Linear.
You should only need 2 keyframes for constant movement.
Post a screen grab of your Curve Editor, or better yet, zip the max file with just the animated material, and post it here.
