Hello how are you guys, well I got a problem too with 3DS Max 2010, no matter if try x32 or x64, got same error when starting, I try execute via compatibility mode, -h via opengl, software and anyway got error, my spects are:
Windows 7 Ultimate SP1 x64
CPU QuadCore AMD Phenom II X4 Black Edition 965, 3400 MHz (17 x 200)
AMD 890FX
16GB DDR3
AMD Radeon R7 200 Series (2 GB)
Your post subject line has been edited by @hagen.deloss: The original thread can be found here
have you added the lastest service pack and hotfixes?
have you setup your VGA drivers inside max link https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/3DSMa...
does max give you a crash reporting error asking you to fill out a form and submit it? if you do once you send it max will give you a crash reporting error ref number with letters if you post it here @hagen.deloss or another empolyee can look it up for you and find an answer or a work around.
Hi @Anonymous
Thanks for bringing your issue to the forums!
I would recommend installing Service Pack 2 for Windows 7, here is an article regarding how to do this.
I agree with @irishman_team_kilber starting Max 2010 using a different display driver could help, and please, if you have submitted a CER report, feel free to direct message me either the CER number, or the email you used to send it 😄
Talk to you soon!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
