Changed my setup from my very old Dual Dell 30inch 2560x1600 60hz + Cintiq 24HD setup to swapping out the middle main monitor for an lg 32GK850F-B 32 inch 2560x1440 144hz GSync monitor in hopes of being able to do digital art and high hz gaming in the same solution.
I got everything set up and going and all seems well. I started 3dsmax and instantly noticed a sort of flickering or strobbing or almost like a "refresh issue" or something. Its subtle. But you see it.
If I move max to the other monitors its fine.
If i disengage 3dsmax (i.e. alt tab to something else) it stops. But so long as you are active on Max the screen does this flickering.
I disabled GSync and it fixed it.
So far this is only in 3dsmax. Apps i've looked for it in are Photoshop, Chrome, Simplify 3D, Zbrush, General Windows apps. Premiere. All are nice and fine.
Ok, I just found the solution! :
- Right Click desktop -> NVidia Control Panel.
- go to Manage 3d Settings on the tree on the left
- Click on Program Settings Tab.
In the drop down box you'll see a bunch of apps and 3dsMax is probably not in there.
- Click [ ADD ] Button. Find 3dsmax and add it.
- go to Monitor Technology in the in the dialog below. Click on the Use global settings and set that to Fixed Refresh.
So far so good for me on this. I'm going to post the thread anyways so people might find the solution faster than I did by running in to this.
Solved by revel68. Go to Solution.
Hey NP. BTW Just so anybody who runs in to this thread knows. This applies to other applications as well. If you have GSync going and detect some annoying flickering in a program you can try the same method for it.
In my case this has often been 3d Printing apps i.e. Prusaslicer. Infact I have it up right now and its flickering - I just don't care because I don't use it like I use Max.
