3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
3ds max won't open
4 REPLIES 4
809 Views, 4 Replies
3ds max won't open
So, I downloaded and installed 3ds max 2017 without any problem. But when I start it it loads the splash screen and then nothing happens. My graphic drivers are up to date. I found that it is a commom problem and there are many probable solutions but none worked. Using dependencywalker I found that these .dlls were missing.
ziparchive.dll
nsarchive10.dll
mgmdfmodel-2_0.dll
mgmdfparser-2_0.dll
I guess these are local 3ds max dlls and not system dlls and should be located in the 3ds max folder.
If anyone has been able to launch 3ds max without any error, I would appreciate if you can give me these dlls.
I cant redownload the 3ds max setup again because I'm out of bandwidth and won't be able to do so till next month. I'd be glad if the solution doesn't require a huge download greater than 500mb.
3ds max won't open
ziparchive.dll
nsarchive10.dll
mgmdfmodel-2_0.dll
mgmdfparser-2_0.dll
Tags (1)
4 REPLIES 4
Alfred.DeFlaminis
Alfred.DeFlaminis
Hello  @Anonymous,
I see this thread is a bit old but I wanted to reply to it.  I have an attachment here of those dlls, but it should be noted that 2017 default installation doesn't include the parser dlls.  (So, they are technically not the reason it won't start for yo.)
They did however exist in my 2014 installation.  I have included them in a folder called 2014 within the archive.
Please keep me posted.  Thank you!
Best Regards,
Hello  @Anonymous,
Best Regards,
Alfred.DeFlaminis
Alfred.DeFlaminis
Hello @Anonymous,
Did this problem resolve itself?  I just wanted to follow up here, is there anything I can do to help you?
Best Regards,
Hello @Anonymous,
Best Regards,
in reply to: Alfred.DeFlaminis
I waited for a long time trying to get 3ds max to work but finally gave and switched to maya (Student version).
Alfred.DeFlaminis
Alfred.DeFlaminis
Hello @Anonymous,
Maya is a great product, I hope it's treating you well.  If you need anything else, please let me know.
Best Regards,
Hello @Anonymous,
Best Regards,
