3ds Max error on Max open
Message 1 of 18
recently got 3dsmax and have been working on some .max files recently had the following error message pop up
now every time I open a max file I get this?!? I'm on windows 10 64 bit latest updates
@Anonymous: I have slightly edited this topic title to make it easier to find via search.  Thanks for your understanding!  -Alfred.DeFlaminis
Replies (17)
Message 2 of 18
irishman_team_kilber
that is a crash max wants to create a autoback of your file, that will be located in your documents folder under the 3ds max autoback all your autoback file are located there you can close that file down and reopen it from the autoback files. but if that countines to happen then it's likely the scene file or just one model
this is just a tip
what i usally do is match the units to the current scene and slowly merge the items one by one, if they all come in fine and the scene does not crash then you the file is fine, but if the scene file crashes then start again and then when you get to the last model and the file crashes then you know what is causing it don't merge that model. you will need to remodel the model.
save it as a new scene file and delete the old one,
Message 3 of 18
happens with every max file i open!
Message 4 of 18
make sure you back up your scenes first have you tried to uninstall 3ds max and reinstall it? and your still getting that?
Message 5 of 18
you mean I have to redownload it!?!?Smiley Mad
Message 6 of 18
do you have the trial, student or full version?
No use the add/remove to uninstall it and reinstall it you should not have to reload it use the icon on your desktop
Message 7 of 18
student
Message 8 of 18
sorry dude i helped you all i can and give you all the advice i can. Your not following it, if you don't know how to uninstall and reinstall a program then i cannot help you
Message 9 of 18
no, i got it, i did a repair will re-install if need be, ill let you know
Message 10 of 18
Re-installed! Repaired! Still get this Error!
Message 11 of 18
i would recommed trying to merge one scene file into the new scene file if you have not tried that.
it could be a crash dump file because sometimes that will tell you what is causing the problem the only problem is unless your a expert you will not understand what is causing it, you would need to have the Debugging tool and the Debugging Symbol drectly from Mircosoft. there could be a number of things causing it.
the only way to create a crash dump file is force max to shut down by hitting ctrl alt and delete and and go to the task manger and RT or LT click on the 3ds max  file, and it will give you a drop down menu it will ask you do create a dump file and then store it in a location but as i said you will need the above Debugging tool and the Debugging Symbol to understand what you are reading
it could be anything From the memory VGA card for example i would not recommend this unless you know how to read it and know what your doing!
Message 12 of 18
lightcube
Reinstalling Max should be your last resort, not first 🙂
You steps for solving should be the following list where you only move onto the next step after the first fails:
  1. Make sure you have the latest service pack for Max
  2. Temporarily uninstall any plugin you recently installed to see if it's the culprit
  3. Temporarily move files out of the folders where MAXScripts are autoloaded from (C:\Users\USERNAME\AppData\Local\Autodesk\3dsMax\2017 - 64bit\ENU\scripts\startup and C:\Program Files\Autodesk\3ds Max 2017\scripts\Startup )
  4. Go to your Max Project folder and rename maxstart.max to another name (if it exists) then restarting Max
  5. Go to C:\Users\USERNAME\AppData\Local\Autodesk\3dsMax and rename the folder that matches your version of Max to something like 2017 - 64bit Backup then restarting Max
  6. Contact AD support
  7. Only if all else fails consider re-installing Max
Shawn Olson
Developer of Wall Worm
3ds Max plugins and Scripts
3ds Max 4/Gmax - 3ds Max 2020
Mudbox 2009-2019
Windows 10 x64
i7 8700K
64GB RAM
Geforce 1080ti
Message 13 of 18
@lightcubeI did not know autodesk offers support? when i call the autodesk tech support they always say "you must contact the authorised reseller you bought 3ds max for support" well that is in the UK!
Message 14 of 18
Alfred.DeFlaminis
Hello @Anonymous,
I'd like to help you with this issue.  Can you please let me know more about the files you are opening?  Did you create them or did they come from elsewhere?  If you were to open Max and make a teapot, save it and try to open it... does it work?  Thanks for any more information you can give me.  At first glance it seems like maybe you are missing a plugin that was important for the scenes and they are crashing as a result.  That shouldn't happen, but occasionally it does.  Also the advice by @lightcube is great, did any of that work for you?  Can you please list your graphics card model for me?
Would it be possible to attach one of those files to a forum post, or PM me a link to one of them so I can investigate?  Or I can create a private folder for you to upload to if that helps.
When Max crashes you often get a CER report box, if you put your email address in there I can search to see what happened when it crashed, and I am happy to do this for you.  I checked the logs based on your forum email address and I do see two of them with some colorful comments.  Smiley Very Happy   In this case you are getting a crash because those files used SP3 for 2016 but you must not have that installed.  Is that possible?
@irishman_team_kilber
Technically I am support but I have sometimes sixty or more forum threads I'm working at any given time.  This is why it takes me some time to get to these new threads, but I almost always do get there.  You can also schedule a call as noted.
EDIT: Checked my notes, I have 60+ right now, not 100.
Best Regards,
Message 15 of 18
Alfred.DeFlaminis
Hello @Anonymous,
I recently replied to your post but I have made an edit to that post with more information. You may not get an email about the edits, so please check the thread.  Long story short, I believe you are missing SP3 for 2016.
Best Regards,
Message 16 of 18
Yeah Thanks! Got it fixed!
Message 17 of 18
Alfred.DeFlaminis
Hello @Anonymous,
Glad to hear it!  Smiley LOL  Thanks for the update!
Best Regards,
Message 18 of 18
I'm facing the same issue and I have tried the following solutions :
1. Update my graphics card
2. Change my display driver
3. Renamed "2019-64 bit folder" in C:\Users\<username>\AppData\Local\Autodesk\3dsMax
5. Switched on Increment saving from the Preferences tab.
6. Reset Preferences.
7. Uninstalled and reinstalled 3ds max.
Also, I have a vray plugin.
If this information helps : I installed Vray as soon as installed Max about 5 months ago and these error messages have started showing just recently from about 2 weeks.
System configuration:
intel core i7
NVIDIA GeForce GTX950M with 4GB VRAM
16gb DDR4 Memory
1000GB HDD
