3ds max stops responding when right click over snaps toggle
nuno_moser
Message 1 of 32
nuno_moser
This happened to me a few times, but not always. After moddelling for some time, when I try to open the Grid and Snap settings, 3ds max gets unresponsive. unfortunatly it doesn't open the error submit window therefore I will never be able to submit an error report for this.
Replies (31)
Message 2 of 32
nuno_moser
I forgot to mention that this is 3ds max 2017 19.0
Message 3 of 32
irishman_team_kilber
do you ever create a dump file? because sometimes that will tell you what is causing the problem the only problem is unless your a expert you will not understand what is causing it, you would need to have the Debugging tool and the Debugging Symbol drectly from Mircosoft. there could be a number of things causing it.
From the memory VGA card, etc
Message 4 of 32
there is one thing you can try that is start a new scene and merge the whole model that you have created into that new file and then give it a new name nd delete the old one this does not work all the time 80% of the time it works
Message 5 of 32
nuno_moser
Thank's for your tips. But it didn't work.
I created a new file, managed to work for a while but after some time it happened again!
This time payed more attention to what is happening:
1. modelling (poly)
2. all snaps disappear. I can't see on screen the symbols (vertex, middle point, end point, etc)
3. when I right click on the snap toggle max gets unresponsive.
Do you know where I should submit the dump file?
Thanks.
I hope my english it not too difficult to read
Message 6 of 32
submit the dumpfile to your desktop but you need to i have the MSdebbuger file
Debugging with Symbols
https://msdn.microsoft.com/en-gb/library/windows/desktop/ee416588(v=vs.85).aspx
Debugging Tools
https://msdn.microsoft.com/en-gb/library/windows/hardware/ff551063(v=vs.85).aspx
hopefully you know what your doing because you can compeletely mess up a windows file you cannot just open it with notepad or wordpad and the file will be read you need the links above
Message 7 of 32
i would first attach the file to here and lets someone take a look at it before using that debug tool that is a last restore using that bug tool.
Message 8 of 32
Alfred.DeFlaminis
Hello @nuno_moser,
I do have a bug logged relating to stability issues on occasion with snapping, and there is a chance this is related.  Does this persist if you use DX9 display driver mode?  I have a link here on how to change display drivers.  Also the dump file as mentioned by @irishman_team_kilber can help, even if it's just to attach to the bug tracker case.  I can't be sure this is the same problem or if this is due to something else, but it's a good start.  Thanks for any updates.
Best Regards,
Message 9 of 32
Alfred.DeFlaminis
Hello @nuno_moser,
I just wanted to follow up here, did the problem lessen with DX9?  Or, is there a dump file that was updated when you froze?  Thanks for any information.
Best Regards,
Message 10 of 32
nuno_moser
I re-installed 3ds max and the problem is gone for now.
Thank you
Message 11 of 32
@Alfred.DeFlaminis them crash dump file are hard to read unless you know what your looking for and they can be annoying and i never took the time to learn about them in windows IMHO
Message 12 of 32
Alfred.DeFlaminis
They are hard to read @irishman_team_kilber.  The CER uploader has an interpreter and formatting side to it so all the data gets parsed on my end.  Convenient.
Best Regards,
Message 13 of 32
nuno_moser
Unfortunately I thought this problem was over after installing 3ds max but ut happened again!!!
I think I'll re-install the OS and everything else to see if it happens again!
Message 14 of 32
nuno_moser
Can you tell-me how can I get the dump file from 3ds max in order to submit-it on the forums?
Is it the 3dsmax.dmp? because it's a huge file (3.14 GB )
Message 15 of 32
If it's that big then you would need to use winrar or filezip these will make the file smaller the problem is i don't know if you can upload them to the autodesk community. i have never tired to use eaither or them
maybe someone else can answer that question or you can try.
Message 16 of 32
nuno_moser
I think this problem may be related with RappaTools hotbox.
I got to this conclusion because I've worked for a while without rappaTools hotbox and I didn't get the problem.
As soon I came back to rappaTools hotbox the problem appeared again.
Has this happened to anyone or just me?
Message 17 of 32
Alfred.DeFlaminis
Hello @nuno_moser,
I was away for a bit there for 4th of July vacation, I am following up on this to see where we're at.  Do you find this only happens with Rappatools?  Can you please confirm for me which update/service pack you are currently using, please?
As far as the dump file I can create a folder for you, but that's a big dump file.  Does max crash or does it just stop responding?  (Do you get a CER report window?)   Lastly, do you find this happens with DX11 and DX9?  NVIDIA released an updated driver last week which may help if it only happens in DX11.
Thanks for any information you can give me about the above issues!
Best Regards,
Message 18 of 32
nuno_moser
Hi Alfred,
I'm using 3ds Max 2017 19.52.915.0
3ds Max doesn't actually crash but the "grid and snap settings" window freezes and I can't do anything else but kill 3ds max task and the CER report window doesn't appear.
I've created a dump file with an empty scene and the size is 2.50 GB
Message 19 of 32
Alfred.DeFlaminis
Hello @nuno_moser,
Thanks for the info.  Do you notice any differences with DX9 vs. DX11?  Also, have you found this only to happen with your plugin?  Thanks!
Best Regards,
Message 20 of 32
@Alfred.DeFlaminis just for my infomation can you use winrar or winzip on this site if the file is that big
Cheers
