3ds max automatically change to a360 cloud rendering mode and unable to choose production rendering mode again
I tried to render my project with production rendering mode, however, it automatically change into a360 cloud rendering mode and i cannot change again to production rendering mode. Even though, I just used it previously in the same working sessions.
I hope to receive the help from you guys.
Thank you in advance.
CiroCardoso3v
Open render setup
Select Targe and select Production
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Thank you for your solution.
However, I tried that but it does not allow me to choose production rendering mode and It automatically change back to a360 cloud rendering mode.
CiroCardoso3v
Does it happen if you start a fresh 3ds Max scene?
Ciro Cardoso
It does not happen when i start the new 3ds max scenes. However, when i turned on again the file that i had had problem, still that problem isn't solved
CiroCardoso3v
Ok, so a easy solution is to merge the old file into a new one.
Ciro Cardoso
Thank you for your kindly support. I solve it by copy the whole objects to the new file and it works.
