3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
3DS MAX 2024 CRASH WHEN I TRY TO EXPORT TO DWG FILE
15 REPLIES 15
Message 1 of 16
jgodiner
899 Views, 15 Replies
Hi everyone, i hope you can help me...when a try to export a file to dwg extension, the 3ds max 2024 crash without any error report, i upload a video showing the problem, i hope you can help me, i used to do the same procedure with a laptop with less resources and i wasn't have this problem.
Regards.
Labels (4)
15 REPLIES 15
Message 2 of 16
Mr.Mxyzptlk
in reply to: jgodiner
Just a shot in the dark but maybe give sini forensics a try. It's free and can clean a lot of stuff out of your scene.
Message 3 of 16
darawork
Are there blocks, ray lines or ellipses in the DWG?
I always explode everything in a DWG before import to 3DSMax.
Ray lines used to crash Max, but I've not tried to import them recently, might be fixed.
Ellipses simply cannot be translated to 3DSMax, and Blocks act completely crazy.
:edit: Ahh, you're exporting, not importing. Hrmm
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Message 4 of 16
jgodiner
in reply to: Mr.Mxyzptlk
I don't have admin credentials, if this software or plugin is not of autodesk, i can't ask for it's installation. 😞
Message 5 of 16
jgodiner
in reply to: darawork
That's correct, i import a fbx file into 3DS Max and i want export to dwg file but when i try it, the software crash, and i don't know why!!! 😞
Message 6 of 16
darawork
Do you have a Dell PC, with Dell Optimizer, Power Management or Backup/Recovery System running?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Crash-occurs-on-so...
These processes may need to be stopped/uninstalled by your IT dept.
Darawork
AutoDesk User
Message 7 of 16
jgodiner
I have a dell precision 7770 laptop, but i don't find any of items that you mention, my company give me that laptop recently and the problem didn't exist in the last one laptop with less resources.
Message 8 of 16
darawork
It looks like you are saving to a OneDrive Synced Folder.
What happens when you try to export directly to your Desktop instead?
Darawork
AutoDesk User
Message 9 of 16
jgodiner
Hi, i tried to export to local desktop and it happens the same!, just crashed without a message error ><'
Message 10 of 16
darawork
If it is crashing without an error message, or customer error submission form... you can check:
C:\Users\*YourName*\AppData\Local\Autodesk\3dsMax\2022 - 64bit\ENU\Network\Max.log
Open that and have a look a the most recent few lines, see if you see anything that might give an indication what the error is. Maybe copy and paste the last most recent 10 lines here. It will not give away any unique identifier information.
Or you can check Windows Event Viewer: [Windows Button]+[R] -> Then type Eventvwr and go to Windows Logs -> Applications and look for a critical error level incident (red circle with exclaimation mark). See if any 3DSMax errors are there.
If we can't get to the bottom of this, I suggest giving the Laptop back to the IT dept and letting them fix it for you. It is currently preventing you from working and they need to fix it. Be it with the help of AutoDesk Support, or the Support of your Product retailer. Low level users (without access to Admin Rights) can only do so much, before it needs to be looked at by the IT dept. It's not your job to fix it, it's theirs.
Darawork
AutoDesk User
Message 11 of 16
jgodiner
Here the last lines of registrer =/, thanks for your help.
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "tokenize".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "codecs".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "token".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "tempfile".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "typing".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "collections.abc".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "xxsubtype".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "shibokensupport".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "shibokensupport.signature".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "signature_bootstrap".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "inspect".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "ast".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "_ast".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "dis".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "opcode".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "_opcode".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "importlib.machinery".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "shibokensupport.signature.typing".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "shibokensupport.signature.lib.tool".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "shibokensupport.signature.mapping".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "PySide2.support".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "shibokensupport.signature.lib".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "PySide2.support.__feature__".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "atexit".
2023/09/28 09:29:48 INF: [26620] [23044] Importing python module "PySide2.QtGui".
2023/09/28 09:29:49 INF: [26620] [23044] Loaded script: c:\programdata\autodesk\applicationplugins\substancein3dsmax2024\scripts\post-startup\SubstanceStartup.ms
Message 12 of 16
darawork
Doesn't look like any errors were logged. Did you have a look at Event
Viewer?
Darawork
AutoDesk User
Message 13 of 16
jgodiner
There is not any error for 3ds max in windows event viewer =/
Message 14 of 16
darawork
Ok, it's looking like a job for IT. I've heard about this happening before
on 2024, but did not see any resolution.
Tell IT to open a support ticket with Autodesk Support personal. They will
be able to remote into the laptop to investigate. Hopefully it can be
sorted soon. At least we tried.
Darawork
AutoDesk User
Message 15 of 16
jgodiner
Thank you!
Regards.
Message 16 of 16
MooneyeTeam
sini is very nice software indeed
