If it is crashing without an error message, or customer error submission form... you can check:
C:\Users\*YourName*\AppData\Local\Autodesk\3dsMax\2022 - 64bit\ENU\Network\Max.log
Open that and have a look a the most recent few lines, see if you see anything that might give an indication what the error is. Maybe copy and paste the last most recent 10 lines here. It will not give away any unique identifier information.
Or you can check Windows Event Viewer: [Windows Button]+[R] -> Then type Eventvwr and go to Windows Logs -> Applications and look for a critical error level incident (red circle with exclaimation mark). See if any 3DSMax errors are there.
If we can't get to the bottom of this, I suggest giving the Laptop back to the IT dept and letting them fix it for you. It is currently preventing you from working and they need to fix it. Be it with the help of AutoDesk Support, or the Support of your Product retailer. Low level users (without access to Admin Rights) can only do so much, before it needs to be looked at by the IT dept. It's not your job to fix it, it's theirs.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
