3ds max 2023 Error Loading
krll_3dsmax
Message 1 of 11
krll_3dsmax
Max Error Loading Plug-In Dll and error loading MaxToA
Replies (10)
Message 2 of 11
krll_3dsmax
OS: Windows 7
DLL <C:\Program Files\Autodesk\3ds Max 2023\stdplugs\MaxPython3Host.gup> failed to initialize. Error code 126 - The specified module could not be found.
Message 3 of 11
Diffus3d
Message 4 of 11
krll_3dsmax
Thanks for your reply, I uninstalled and reinstalled all versions VC to the latest version. But unfortunately it didn't help.
I post all post-launch errors, including those related to Arnold:
Error Loading Plug-in DLL
MAXScript Auto-load Script Error Exception
—	Type error: extends: requires MAXClass, got: undefined
—	File name: c:\programdata\autodesk\applicationplugins\ maxtoa_2023\maxscript\arnoldlight_gobofilter.ms
-- Line number: 0
—	File name: c:\programdata\autodesk\applicationplugins\ maxtoa_2023\maxscript\arnoldlight_decayfilter.ms
-- Line number: 0
—	File name: c:\programdata\autodesk\applicationplugins\ maxtoa_2023\maxscript\arnoldlight_barndoorfilter.ms
-- Line number: 0
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldGeometryPropertiesModifier.dlm> failed to initialize.
Error code 127 - The specified procedure could not be found.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldProceduralObject.dlo> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\MAXtoA_Menu.gup> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldLightFilterModifier.dlm> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldVolumeObject.dlo> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldShadersLoader.gup> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldLight.dlo> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldUSDObject.dlo> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldFluidUtil.dlu> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\ArnoldAlembicObject.dlo> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\MAXtoA.dlr> failed to initialize.
DLL <c:\programdata\autodesk\applicationplugins\maxtoa_2023\OperatorGraphPlugin.dla> failed to initialize.
Message 5 of 11
Diffus3d
Weird.  Did you reboot after uninstalling them?
What happens if you uninstall Arnold, all works then?
Best Regards,
Message 6 of 11
viptory
I have a similar situation. I removed the Arnold renderer. This improved the loading of the program. But these errors have not disappeared. How to fix them?
Message 7 of 11
raiden_xavier
Hi @viptory,
Thanks for sharing this with us.
Have you got Python installed?
Something may have gone wrong with your install.
You should not be seeing any issues with Substance.
Message 8 of 11
viptory
Hello.
Everything is much easier.
This 2023 version does not work properly in Windows 7.
Since Python installed in 2023 version does not work in Windows 7
Message 9 of 11
jon.bell
Hi @viptory,
Since Windows 7 has been deprecated by Microsoft and is no longer supported, it's not surprising to see these errors.
Can you confirm that you're trying to run 3ds Max 2023 and MaxtoA under Windows 7? If so, then that's not a supported configuration (Windows 10 and 11 only). Thanks,
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Message 10 of 11
viptory
Hello. I installed the new Python 3.9 on Windows 7
Thanks to these people. https://github.com/NulAsh/cpython/releases/tag/v3.9.9win7-1
Many programs work. But you need to replace the libraries. Are there any ways to fix this problem that I have in the photo?
Message 11 of 11
jon.bell
Hi @viptory,
Again, please note that 3ds Max 2023 is certified to work under Windows 10 and Windows 11 only. Microsoft ended all Windows 7 support in January 2020, and we can't recommend running the latest versions of Max under it.
My advice (as painful as it may be) is to back up all your data, then upgrade your PC formally to Windows 10.
Jon A. Bell
