Oversized Tape Measure Icons Issue
night_daimon
night_daimon
Hello, I'm trying to figure out how to adjust the size of Tape measure icons, viz., the arrow helper and box target, to a reasonable size. As you can see in the attached image, they are far too large to manage. The squares in grid are set for one foot. Thank you in advance.
Diffus3d
Hello @night_daimon ,
You can adjust those sizes I believe in Customize->Preferences->Viewports->Non-Scaling Object Size.  (for most things that don't scale like helpers.)   Does it work for your issue?
Best Regards,
night_daimon
Hi Diffus3d, I did follow the path you provided and adjusted the Non-Scaling Object size, but it had no apparent effect. I then clicked on Restore Factory Settings and that seemed to correct the problem. Thank you for help!
Diffus3d
Glad to hear it and thanks for posting your solution!
Best Regards,
