3ds max 2020 maxscript auto load script error
Hello there .
after a while i wanted to use my 3dsMax 2017 but unfortunatly it gave 0xc0000005 error
so i've tried all solutions in forums and etc it didn't work out . so i went to instal 3dsMax 2020
I had many troubles with error loading plugins etc so i deleted them . and finally i faced the error mentioned in the title . as i saw foroums , i should put the erorr in Max script listener . but the foroum mark it as spam so i post it later
as you see these screenshots
https://ibb.co/j5YqZct
https://ibb.co/4scVRdy
https://ibb.co/3syn3k0
https://ibb.co/4fgKFhr
https://ibb.co/vsVkxYH
Daf
Hi there,
That's a lot of .net errors  - There are a couple of things I would try.
1 - You may either be out of date on your .net framework or they've possibly become corrupted. I would check your Windows installation for any needed updates or visit the MS .Net Framework site and update manually -
https://dotnet.microsoft.com/download/dotnet-framework
2 - It's also possible that the scripts/plugins you are trying to load are not compatible with the current version of Max (2020) - check the sites of those scripts and see if there are updates.
That's my two cents - hope it helps!
Good luck!
Daf
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
when i wanted to update it . it said
.NET Framework 4.8 or a later update is already installed on this computer.
 and i've updated to the latest version of windows 10 .
Btw i cleaned and unistalled it from everywhere and resgisteries etc ... and managed to instal 3ds max 2017 and still have these error with a bit differecne
and i just installed it . so no plugins or etc
https://ibb.co/fk9mGB6
https://ibb.co/fCvFP7z
https://ibb.co/k30PXNH
https://ibb.co/KDzztRd
https://ibb.co/9yt97dv
https://ibb.co/qYR4Gmx
Daf
Check out this article and see if it helps
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Plug-i...
Then check this google search for articles that may have more info
https://www.google.com/search?&q=the+assembly+mxsdotnet.dlx+encountered+an+error
Best I can do I'm afraid. It definitely appears to be .Net related. I hope you get it sorted.
3DS Max 2020.3
Actually i tried those already it won't work . and there are many people with same problem with no solution , hope Autodesk do sth with it and fix our problems .
Any one knows how to fix * Maximum Nested error dialog depth reached * error?
I am also having same error but not getting any solution 😞
