3ds max 2020 maxscript auto load script error
Message 1 of 1
Hello there .
after a while i wanted to use my 3dsMax 2017 but unfortunatly it gave 0xc0000005 error
so i've tried all solutions in forums and etc it didn't work out . so i went to instal 3dsMax 2020
I had many troubles with error loading plugins etc so i deleted them . and finally i faced the error mentioned in the title . as i saw foroums , i should put the erorr in Max script listener . so here it is
as you see these screenshots
https://ibb.co/j5YqZct
https://ibb.co/4scVRdy
https://ibb.co/3syn3k0
https://ibb.co/4fgKFhr
https://ibb.co/vsVkxYH
Welcome to MAXScript.
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\CharacterPluginObject.ms; position: 10412; line: 304
-- MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\CharacterPluginObject.ms Exception:
-- Syntax error: at dotNetControl, expected <rollout control>
-- In line: function g
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\MCG_functions.ms; position: 564; line: 14
-- MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\MCG_functions.ms Exception:
-- Compile error: Undeclared variable: dotNetClass
-- In line: NodeWrapperClass = dotNetClass "
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\MergeAnimation.ms; position: 3597; line: 54
-- MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\MergeAnimation.ms Exception:
-- In line: dotNetControl l
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\NET_ListViewWrapper.ms; position: 439; line: 16
-- MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\NET_ListViewWrapper.ms Exception:
-- In line: m_dnColor = dotNetClass "
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\NET_TreeViewWrapper.ms; position: 454; line: 15
-- MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\NET_TreeViewWrapper.ms Exception:
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\(MassFX)\px_globals.ms; position: 75363; line: 2969
-- MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\physx_startup.ms Exception:
-- Type error: Call needs function or class, got: undefined
-- MAXScript callstack:
-- thread data: threadID:20668
-- [stack level: 0]
-- In anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\(MassFX)\px_globals.ms; position: 75364; line: 2969
-- Locals:
-- Externals:
-- PHYSX_AUTODESK_VER: Global:PHYSX_AUTODESK_VER : true
-- [stack level: 1]
-- called from top-level
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\CATScripts\CaptureAnimation.ms; position: 1626; line: 38
-- MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2020\stdplugs\stdscripts\CATScripts\CaptureAnimation.ms Exception:
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_BakeTextures.mcr; position: 166650; line: 4475
>> MAXScript MacroScript Compile - C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_BakeTextures.mcr, offset 166650; Exception:
-- In line: group ~ <<
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_MCG.mcr; position: 27543; line: 744
>> MAXScript MacroScript Compile - C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_MCG.mcr, offset 27543; Exception:
-- In line: button b <<
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_MCG.mcr; position: 31058; line: 856
>> MAXScript MacroScript Compile - C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_MCG.mcr, offset 31058; Exception:
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_NamedSelSets.mcr; position: 8649; line: 199
>> MAXScript MacroScript Compile - C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_NamedSelSets.mcr, offset 8649; Exception:
-- In line: dotNetControl v <<
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_UIScheme.mcr; position: 10798; line: 305
>> MAXScript MacroScript Compile - C:\Program Files\Autodesk\3ds Max 2020\MacroScripts\Macro_UIScheme.mcr, offset 10798; Exception:
-- MAXScript ExecuteMAXScriptScript Exception:
-- Unknown property: "isDisplayed" in undefined
-- [stack level: 0]
-- In top-level
-- [stack level: 0]
-- In top-level
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\scripts\startup\ProceduralContent.ms; position: 396; line: 10
-- MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2020\scripts\startup\ProceduralContent.ms Exception:
-- Unknown property: "LoadAssembly" in undefined
-- [stack level: 0]
-- In LoadAssemblies(); filename: C:\Program Files\Autodesk\3ds Max 2020\scripts\startup\ProceduralContent.ms; position: 397; line: 10
-- member of: StructDef:ProceduralContentOps
-- Locals:
-- bridgePath: "C:\Program Files\Autodesk\3ds Max 2020\Viper3dsMaxBridge.dll"
-- dotnet: undefined
-- maxPlusPath: undefined
-- Externals:
-- owner: (ProceduralContentOps)
-- [stack level: 1]
-- called from SetUpCurrentUser(); filename: C:\Program Files\Autodesk\3ds Max 2020\scripts\startup\ProceduralContent.ms; position: 3846; line: 105
-- Locals:
-- Externals:
-- ReloadOperatorsAndCompileTools: Struct member:ReloadOperatorsAndCompileTools : ProceduralContentOps.ReloadOperatorsAndCompileTools()
-- SetupUserProfileFolder: Struct member:SetupUserProfileFolder : ProceduralContentOps.SetupUserProfileFolder()
-- RegisterCustomGraphPaths: Struct member:RegisterCustomGraphPaths : ProceduralContentOps.RegisterCustomGraphPaths()
-- LoadAssemblies: Struct member:LoadAssemblies : ProceduralContentOps.LoadAssemblies()
-- RegisterForPreLoadMaxFile: Struct member:RegisterForPreLoadMaxFile : ProceduralContentOps.RegisterForPreLoadMaxFile()
-- [stack level: 2]
-- [stack level: 0]
-- In top-level
-- [stack level: 0]
-- In top-level
-- [stack level: 0]
-- In top-level
-- [stack level: 0]
-- In top-level
-- [stack level: 0]
-- In top-level
-- [stack level: 0]
Replies (0)
