3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
3ds max 2020 can't save file
24 REPLIES 24
Message 1 of 25
46182 Views, 24 Replies
3ds Max 2020 can't save file, just export. How to solve it@
24 REPLIES 24
Message 2 of 25
Why will not nobody answer?
Message 3 of 25
alternative way is to export as 3DS (3D studio) but it will loose mapping coords, curve frame keys and some datas
Message 4 of 25
facing same problem me too .
Message 5 of 25
rendermaster
what is the message that appear when saving file.?
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 6 of 25
What do you mean by ‘refuses to save anything’? Does it error or display a dialog at all? Is the file you are opening set to read-only? Does it autoback? Can you save it as a new name like olx in a different location? Just that file or anything? Is it possible to import or merge into a new scene, then save?
Please reply then we will discuss further.
Message 7 of 25
tom356
in reply to: rendermaster
Im having the same trouble with max 2020 just wont save, anyone figure out why..
I tried to reinstall still the same can export, open old files cant save as with old files also.
Message 8 of 25
I'M HAVING THE SAME ISSUE OO! I HAVE UNINSTALLED AND INSTALLED AGAIN,YET STILL CAN'T SAVE.
IS THERE ANY SOLUTION TO THIS?
Message 9 of 25
I click save, type a name for the file then click save. Then when I check the folder in windows explorer, the file's not there.
Message 10 of 25
 I'm having the same problem as you. So I revert to a previous version (the 2018), as it accept the material updates I made (installing a new graphic card, and adding memory to my system).
 The main problem comes from the software, as changing the properties of the folders won't change the saving problem.
 3DS Max also ask for obsolete file format, when opening an older max file (from a previous version). But is does not save it, wherever you want to place the file.
 It still accept the export way for saving files. So I'm trying to change the register association files, so that max files are open with the newer version of 3DS. But I don't expect much from it.
 You can ask the maintenance service of Autodesk, and also try a new clean install (if you have time). I'm also trying a new complete reinstall of all of my system, on a new hard drive. I'll write about it in 1 or 2 weeks. It may run this way, installing 3DS Max2020 as the first external software on windows.
Message 11 of 25
jon.bell
Hi everyone,
Can you please confirm that you are running (or have downloaded and installed) the 3ds Max Security Tools for all your copies of 3ds Max?
Some problems caused by the ALC/CRP MAXScripts include breaking 3ds Max Save functionality, so please make sure you've installed these and have them running, and let us know if this behavior is continuing. Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Message 12 of 25
jon.bell
in reply to: jon.bell
Hi everyone,
Any updates to this issue re: saving Max files? Have you installed the Security Tools mentioned in my post above?
Please let us know, and thanks for your feedback!
Jon A. Bell
Message 13 of 25
hi Jon, thank you for the suggestion
but I still can't save my file..when I save the file, the untitled file name here changes to any file names I typed in, indicating it has saved the file but when I checked to the file destination (on desktop), I can't find my file.
and when I try to quit, this popup message came, meaning the file isn't actually saved
I don't know how to repair this I need to save my files 😢
Message 14 of 25
jon.bell
Can you please confirm that you've installed the 3ds Max Security Tools and are running them?
Also, are you running on a school machine, or a machine that has strict security policies? Are you able to save any file (such as a text file) to your local desktop? (This may be a permissions issue.)
In addition, can you try saving your Max scene file to a different location, such as a C:\Scenes folder?
Please let us know, and we hope to hear from you soon!
Jon A. Bell
Message 15 of 25
jon.bell
Hi Adin_ach,
Any updates on this issue, or does the problem seem resolved for now? Please let us know, and thanks!
Jon A. Bell
Message 16 of 25
Hi Jon, sorry for the late reply, I gave up trying to save the file. So I saved it as a .3dsfile because its the only way to at least save my file, and then I downgraded my 3ds max to 2018 which has no problems in saving the files.
So sorry everyone who is trying to get some answers!! I still don't know yet
Message 17 of 25
jon.bell
Hi Adin_Ach,
There's no reason why you shouldn't be able to save a 3ds Max .max file anywhere on your PC if you have proper permissions, a proper install and sufficient disk space.
I could mark this thread as Solved, but that really doesn't address your issue. If you don't mind, could you please create a technical support case for this problem, put my name in the title, and let me arrange a Team Viewer session and phone call with you so I can see this problem first-hand on your PC?
Please let me know (you can send me a private message, if you want) and I hope to hear from you soon!
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Contacting-a-technical-s...
Jon A. Bell
Message 18 of 25
jon.bell
Hi Adin_Ach,
I sent you a private message with a folder link. If possible, I would very much like to get a File > Archived version of the 3ds Max scene that you couldn't save so I could test it here.
Could you please let me know if this is possible? Thanks!
Jon A. Bell
Message 19 of 25
this problem already solve.
Message 20 of 25
shilpy.pchopra
how can we resolve this issue, could you please share
