3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
3ds MAX 2018 Crash when opening scene file HELP!
5 REPLIES 5
Fahad_ALAsmari
2271 Views, 5 Replies
Fahad_ALAsmari
Hello everyone, I have a strange problem I have sample scene and when I try to open it on my workstation it crashs 3ds max 2018 "an error has occurred and the application will close" in the same time it opens fine on my laptop!? what should I do? Re-install I have done many times.
5 REPLIES 5
danderson
in reply to: Fahad_ALAsmari
danderson
Fahad_ALAsmari
in reply to: danderson
Fahad_ALAsmari
Thank you so much but that didn't help at all that's why I already  Preform a clean uninstall, what makes me go crazy is that the files are working fine on my laptop!, it can be GPU drivers or any Hardware related problem?
jeffrey.sin
Hi @Fahad_ALAsmari,
Since it only affects the 3ds Max 2018 on your workstation, it could be a hardware or driver issue. Check out the suggestions in this Autodesk Solution:
Application Error occurs when launching 3ds Max
Hope this helps, let us know how it goes. Thanks.
Jeffrey Sin
Autodesk Customer Support
Hi @Fahad_ALAsmari,
Jeffrey Sin
Fahad_ALAsmari
I will try to change the graphics drivers.
in reply to: jeffrey.sin
Hi @jeffrey.sin
I tried all of these recommendations and followed countless other ideas to solve this exact issue but it still isn't working on my end. My 3dsMax 2018 starts up fine and all of the functionality works, but when I open ANY max file, even ones that worked fine yesterday it just crashes and gives me the same error, I even did a Clean Uninstall and a System Restore to week back, This issue still persists.
Any other ideas?
Rynhardt
Hi @jeffrey.sin
Any other ideas?
Rynhardt
