3ds Max 2017 New Mirror Command
SerdarHakann
Advisor Advisor
SerdarHakann
Let’s take a closer look at what the new Mirror command in 3ds Max 2017 can do!
1- Select a box as your Object Type. Click on the Mirror command as shown.
2- Choose Geometry. Click on Copy. Finally, hit the OK button.
3- As you can see a copy of our box was created and modified by the mirror command which was not included in the previous versions.
4- When you close the Eye icon located next to the Mirror command on Modifier List you will see that we closed in the box.
5- You will see a new Mirror command sub-menu when you click on the arrow located next to the Mirror command.
Serdar Hakan DÜZGÖREN
Autodesk Expert Elite
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ile ödüllendirin.
3D Generalist |Serdar Hakan.NET | Serdar Hakan AKADEMİ Türkiyenin Online Eğitim Akademisi |
serdarhakanakademi
I am a bit confused, the exact same modifier exists in 3DS Max 9.  I don't have it installed so can't check the copy option but it is for sure in 2013 ... long time before 2017
