Have just installed 3ds max 2016 sp4 and when I start up 3ds max it gives error >>> @!&*# <<<25
It was fine before on 3ds max 2016. I have Windows 7 64bit on my main computer and then on my laptop computer with Windows 10 64bit it gives the same error.
Thanks for any advice.
Hello @wrreisen,
I'd like to help you with this error message. I don't have any notes for this particular message so I'll need to suggest a few things to try so we can narrow this down. First, can you please try to reset your user settings for me? Second, this may be a license service error somehow... could you please type "services.msc" in a search blank in windows and open your services panel? Is the FlexNet license service running?
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @wrreisen,
I just wanted to follow up here, any progress on this issue?
Best Regards,
I got the same problem on Win 10 x64. I did what you said but it didn't help because Flexnet is already running automatically. Please reply. TIA.
Hello @stevenguyen24793 and welcome to the community,
Did you try to reset your user settings? Do you use any tablets or 3rd party hardware like a 3D mouse? Lastly, if you make a new user in Windows and try again, does it work?
Best Regards,
Very strange, thank you for posting that @Anonymous. Does renaming it and naming it back again help for you @wrreisen and @stevenguyen24793?
Best Regards,
