3ds max 2016 issues
3ds max 2016 issues
With 2016 whenever i select an object it appears to move in the viewport, making me very nervous that nothing will actually be where it should be (even when the move tool isn't active)
Also when selecting an object the view seems to teleport to some random corner of the model of fades out....
Ive tried it on ortho/perspective and every viewstyle.
Really starting to annoy me! any fixes???
Ta
Paul
Replies (30)
Steve_Curley
Could be a number of things, most likely are the size of the objects in terms of the System Units and the location of the objects with respect to the world origin.
Try loading Max, change the System Units to cm, change the Display Units to Generic, create a 10cm Cube and move it to the Origin.
Do you get the same problems manipulating that cube? If so, save the scene, Zip it and attach it to a reply so we can take a look - it should work without any problems.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Having the same problem as OP with max 2016, everytime it would randomly teleport to another location in the viewport especially
moving objects in the viewport.
Tried the same file with max 2015, no such problem.
Steve
No such problems with a simple scene with a cube.
The problem seems to kick in randomly, a reboot will solve it temporarily.
The scenes im working on aren;t overally big, all set to 0,0, 130k polys. i;ve tried changing the graphics driver  from Nitrous Quadro K5000).
Going back to 2015 till the hotfix is rolled out.
Ta
Paul
office
Are you sure that this occurs when selecting objects and not navigating around them? I'm having the same problem but only when navigating around objects that are further than the origin point of the scene. I should mention that this never happened to me with Max 2014.
3ds Max subscription customer since 2010
| Max 2022.1 | AMD Threadripper 3970X 32-core | 64GB RAM | Nvidia GeForce GTX 1080 Ti FE 11GB | NVMe SSD Samsung 960 Pro | Win10 Pro x64 | Nvidia Driver 466.47
dave.tyner
Hi all, just figured I would chime in on this one. The symptoms all sound like high coordinate type problems. What sofware are the files you're importing from?
FWIW have you tried:
  • Move to 0,0,0 > Reset Xform > convert to poly/mesh?
  • or
  • Move to 0,0,0 Reset Xform > Export to obj > reimport
-Dave
hi,
  Having a similar issue, is it anything like this screencast i made?
http://autode.sk/1RTdKdg
I have seen a couple other posts around the forum for something similar, Like to point out to autodesk that it doesn't happen when i open the same file in 2016.
Having this issue as well, object teleport when you move tham, and randomly,seems to have something to do with mouse input as only happens whn unclicking or moving the mouse.
dave.tyner
if you move your objects to 0,0,0 do you experience the same behavior?
Yes when placed at 0,0,0 the problem persists, and creating a new scene and merging all objects into the new scene seems to fix the issue. Restarting does not fix the issue.
hi,
   I get this sometimes (only in 2016 and not in previous versions) in ortho view, found that if flip it to perspective mode, move around  and play with the zoom, then flipping back to ortho mode, it seems to fix it (for a while anyway)
How do I install plugins for 3ds Max 2016?? I really need this one plugin to be able to do something but I don't know how to install it.
iadproductions
Was there a read me file with the Plugin that had install instructions ?
Plugins usually get installed in C:\Program Files\Autodesk\3ds Max 2016\Plugins
Mastering Autodesk 3ds Max 2013
http://www.amazon.com/Mastering-Autodesk-3ds-Max-2013/dp/1118129717/ref=zg_bs_4135_2
No, there was no readme file in there =(
dave.tyner
What plugin are you trying to install?
CannonFodder's Half-Life 2 SMD Importer
dave.tyner
Here is the readme for the 2012 64bit (latest version)
This is modifered version of the Valve smd exporter
which supports weights and the max skin modifer.
It also fixes a problem where textures assigned to a model
(instead of faces), was being ignored.
This version now supports export selected
The exporter does NOT require the use of multi-subobject
materials. A standard material with a bitmap assigned to
the diffuse channel is all that is required
I have also included a compiled version of the VTA exporter
from the Source SDK. This is used with the morpher modifier
to create facial animations.
Version 2.04 adds the ability to specify an animation range, use the material name instead of
the diffuse name and provides a maxscript interface. To call from maxscript use the following
ExportSMD <filename> <Export Selected> <Reference> <Flip Normals> <Mirror Normals> <Use Material> <Animation Start> <Animation End>
e.g.
ExportSMD "test.smd" false true false false false "1" "2"
Place these in your Program Files/Autodesk/3ds Max 2012/plugins directory.
Cannonfodder
Look for updates @
www.chaosincarnate.net/cannonfodder/cftools.htm
cannonfodder@chaosincarnate.net
I saw 2012 a couple time in there, will it still work with 3ds Max 2016??
Customize | Preferences | Gizmos | Move/Rotate Transforms | set to Projection (instead of Intersection).  Autodesk broke this in 3dsmax2014.  It caused a behavior where when snap was activate and you were not actually snapping the object but rather moving its pivot would center itself on your cursor causing the jumping movement described.  Drove me crazy as well.
dave.tyner
Doesn't work for me. Author will have to recompile for 2016 most likely
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
