3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
3dMAX 2015 Vray Sun and Render
16 REPLIES 16
Message 1 of 17
3134 Views, 16 Replies
Hi 3d max community,
I am Using Vray for the first time, i had alot of problems and issues that I can't understand and I was trying to solve it but I couldn't. The model is 50x70m and whenever i put materials and render it gave me this colors. Even though if i put materials.
Iam using vray sun but its too much bright and there is this brown color that i don't know from where it comes.
here is the settings.
It was in REVIT and once i import, it gave me the same issues, then i RE-Built it in 3dmax trying to solving it , but it doesn't. Can anyone explain to me what is happening!
Your post subject line has been edited by @hagen.deloss: 3dMAX Vray Sun and Render
16 REPLIES 16
Message 2 of 17
surrealismo
how is your gamma settings?
Message 3 of 17
in reply to: surrealismo
Finally someone answer, I was waiting a long time, really thanks.
Here is my Gamma setting
I still have the problem
Message 4 of 17
surrealismo
ok. could you upload the file so I can check it for you?
the brown color is the ground albedo from vraysky. you can offset it, check sun settings.
Message 5 of 17
ammarshow
did u use camera ? or u did u render from the viewport  ?
Message 6 of 17
Here is the file Link
https://files.fm/u/4shqwpgz#_
I tried offset but it doesn't work
I have 3dmax version 2015 in case if u solve it, I'm very thankful for you.
Message 7 of 17
in reply to: ammarshow
Yes I'm using camera
Message 8 of 17
surrealismo
I´ve checked your scene and found the problem.
On the VrayFramebuffer, you need to activate ¨display colors in srgb space¨.  it´s in the bottom menu.
and check again the Horizon offet.  I put 10 and the brown color disappeared.
Message 9 of 17
 Thank you its really much better,  but i still have a question.
 Why is the materials are very light, it doesn't show as its in the diffuse map. For example here am using Dark brown wood but it shows very light. Even the shadow are very dark.
Message 10 of 17
surrealismo
hmmm it seems you have a problem with linear workflow and textures on gamma 1.0, 2.2 or viceversa.
Message 11 of 17
How can i solve it ?
Message 12 of 17
surrealismo
difficult to solve without look the scene.
can you zip the scene to take a look and help you out?
Message 13 of 17
hagen.deloss
Hi @Anonymous
Looks like you are getting some great help here from @surrealismo and @ammarshow, I wanted to add that this article may have some helpful information on the Vray workflow. It looks like the scenes' light (the sun) is washing out your materials. You could try lowering the gamma from 2.2 to something like 2.0 and see what that changes, or finding the intensity of your sun, and lowering it just a little.
I hope this helps!
I also wanted to remind you, if someone posts a solution that helps resolve your issue, you can click the Accept as Solution button, that way the rest of the community can benefit from the knowledge found within this thread!
Talk to you soon!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 14 of 17
HERE IS THIS SKIN
https://files.fm/u/67e2h9hm
Message 15 of 17
in reply to: hagen.deloss
Hi
Message 16 of 17
hagen.deloss
Hi @Anonymous
I got your private message, and figured I would post back into this thread, since your still dealing with the same issue!
I don't have Vray on my machine (only mental ray currently), but I still think its the exposure settings. Have you changed the ISO properties on your camera? Here is an article on how to edit scenes lighting with the ISO camera controls. If you would post the screenshot you sent me, then we can compare the original render with the resulting render after you edit the ISO settings!
It looks like this post on the forums had a similar issue, and it looks like the narrowed down the cause to the camera as well, lets see what kind of exposure controls the camera offers, and if there is a Vray specifica camera that you can create.
I will unmark the previously marked solution as well until we figure this out 😄
Hagen Deloss
Message 17 of 17
hagen.deloss
@Anonymous
I wanted to check back and see if a post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
