we're doing a 3d scene and rendering with V-ray, but we need to know if there any plugin for oculus rift realtime camera viewing inside 3dsmax?
or will it be available in the upcoming versions of Max?
v-ray has already released a beta version of vray 3.50 with oculus mode support in Realtime.
any suggestion ?
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @Anonymous and welcome to the community,
Sounds like you are doing some cool things over there!
For realtime VR support, Stingray is the current application that has the most features from Autodesk. You may find 3rd party plugins for VR in Maya and Max but it's not currently supported natively.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Has anyone tried Stingray? Is it easy to set up - would be good to just have a viewport dedicated to VR, without having to switch.
Okay Alfred thanks, but the issue is that i am using v-ray renderer with v-ray materials... so how can i achieve this? any idea ?
Hello @Anonymous,
Not possible, as far as I know. Vlado has a thread about this on the Chaosgroup forums, but Vray isn't a realtime renderer so you'd have to render a pano and load it in.
Best Regards,
Hello @Anonymous,
I went to find the thread on the Chaosgroup forums to link to you, but then I noticed it was your thread! Small world. Time will tell on this issue, I'm a huge Vray fan myself so I'm also looking forward to whatever Vlado cooks up here.
Best Regards,
Can you really only do Architechure in 3ds Max Interactive? (also, Is it called that? 3ds Max Interactive? I'm confused with this Stingray stuff... I would want to bring Characters in,. What materials do you use in MAX to show up in 'Interactive' that has Normal Maps potential?? THANK YOU!
