3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
2nd UV channel won't save
1 REPLY 1
725 Views, 1 Reply
I'm trying to create a shadow map and require a 2nd uvw channel to do so.
Using the unwrap modifier to create the map in the 2nd channel is ok, but after collapsing the stack, if I go back and re-open the modifier the 2nd channel UV's haven't been saved.
Any ideas?
1 REPLY 1
OK, problem solved.
Apparently I have to press Reset to update the channel when I re-open it. Duh!
They stayed up nights thinking that bit of programming out.
