2017 - where is the option to disable 'wireframe object on selection'
jibijib
Message 1 of 12
jibijib
It seems to have disappeared or has been moved in 2017.
Does anyone know where it is, or am I going blind?
Replies (11)
Message 2 of 12
irishman_team_kilber
cycle through the F3 and F4 combinations to show/hide this wireframe in the newer verison they mite have changed it.
go to the viewport label LT or RT click and you will get a drop down menu you will see the wireframe check/ticked or uncheck/unticked
Message 3 of 12
jibijib
Message 4 of 12
jibijib
I know how to turn wireframe on and off - this isn't the problem I'm having.
When you select any object with or without the wireframe (coloured to the colour of the object), it turns the wireframe white. With no wireframe active, it shows the wireframe.
There was an option in 2016 to turn this off, it's gone.
Message 5 of 12
I've just answer this question we are not always on this fourm we have jobs to do and lives to lead. i would get myself a 3ds max keyboard so it would be eaiser and you know what the options are with the 3ds max keyboard. the keyboard will have all the shortcuts what you need to know in max
maybe you need to be specific in your question we are not mind readers. and you shoudn't post your question without all the details then we won't speculate about your question
Message 6 of 12
jibijib
The problem is in the title of the thread.
It appears this has been moved or just removed completely. So if you want to see the model without the wireframe on it, you have to get out of subobject mode and completely deselect.
Message 7 of 12
jibijib
Can anyone help with this - just need to know where the option has been moved to in 2017?
Message 8 of 12
jibijib
bttt
Message 10 of 12
jibijib
Thanks - will see if that's the one when I get home.
Message 11 of 12
Alfred.DeFlaminis
Hello @jibijib,
I just got to this thread, @Swordslayer has the answer I think you are looking for.  Can you please confirm for me?  Thank you very much and happy holidays.
Best Regards,
Message 12 of 12
Alfred.DeFlaminis
Hello @jibijib,
I just wanted to follow up here, any progress on this issue?
Best Regards,
