REVIT object import resolution import to 3D Max
Francisco_Penaloza
Francisco_Penaloza
I have this issue every time I try to export Object from REVIT to 3ds Max. While in REVIT most objects look fine, curved, and smooth and the edges are well defined, When I export to 3D s Max they just look crappy.
I have tried different methods, also exporting using FBX, DWG, DXF, and the edges looked fine, but curves or corners just don't look correct.
When I model something in AutoCAD using Solids, I can adjust the resolution inside 3Ds Max while importing, and everything looks great but withing REVIT I can find a way to control the quality of the sweep.
Please take a look at these screenshots, one is from REVIT viewport the other from 3Ds Max.
Thanks.
Jos_Heruvent
Maybe this helps.
If you go to File in Max then select Reference and then Manage Links.
Then click Presets at the top and select the preset that is right for you.
Then click Modify.
Here you can set the smoothnes under Geometry.
Then you can download your exported file from Revit under Attach.
Francisco_Penaloza
Thank you for your answer, but that doesn't fix the problem, I already tried many combinations on those settings also when you link a REVIT to 3Ds Max and still same issue.
I am surprised that no more people are mentioning this, Maybe most users replace the furniture anyways.
My main issue is sometimes I get these models from the manufacturer so my only choice is to rebuild those parts.
Jos_Heruvent
You may need to change the setting in Revit before export at the bottom left to Fine and Realistic.
neflonm44
Community Visitor
Community Visitor
The Autodesk 3ds Max Forums are an online community where 3ds Max users can share their knowledge, ask questions, and discuss various topics related to 3D design visualization. To access the forums, you can follow these steps:
  1. Go to the Autodesk 3ds Max website.
  2. Click on the "Support & Learning" tab at the top of the page.
  3. Click on "Forums" in the drop-down menu.
  4. On the Forums page, you can browse through the various topics and discussions or use the search bar to find specific information.
  5. To participate in a discussion or ask a question, you will need to create an account and log in to the forums. Once you have logged in, you can start a new discussion or reply to an existing one.
The Autodesk 3ds Max Forums are a great resource for learning and connecting with other 3ds Max users. Whether you're a beginner or an experienced user, there is always something new to discover and explore in the forums.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
