REVIT object import resolution import to 3D Max
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have this issue every time I try to export Object from REVIT to 3ds Max. While in REVIT most objects look fine, curved, and smooth and the edges are well defined, When I export to 3D s Max they just look crappy.
I have tried different methods, also exporting using FBX, DWG, DXF, and the edges looked fine, but curves or corners just don't look correct.
When I model something in AutoCAD using Solids, I can adjust the resolution inside 3Ds Max while importing, and everything looks great but withing REVIT I can find a way to control the quality of the sweep.
Please take a look at these screenshots, one is from REVIT viewport the other from 3Ds Max.
Thanks.
