Autogrid does not seem to work anymore
ryan_lepianka
Observer Observer
ryan_lepianka
Observer
Observer
Autogrid has been working inconsistently for years now.  At times when I try to draw on the angled face of an object, the grid functions as if the face were at an angle other than what it actually is.  Not horizontal or vertical, but at some odd angle in-between.
Hello @ryan_lepianka
From your screenshot, could you check is there any default smooth groups in your object? If yes, you should remove all smoothing groups from it. Just apply a smooth modifier which removes all smooth groups by default and then retry to Auto Grid again. Let me know the result. Thank you.
If this helps you solve your issue or answers your question, please hit the "Accept as Solution" button, so I will know that I was useful in helping you. Thank you very much for doing so.
Best Regards,
Gogein Alois Gontoro
Autodesk® Student Expert
Autodesk® 3Ds Max® 2015 Certified Professional
Surabaya, Indonesia
