- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi All,
So, I am attempting to animate a roller shutter opening/closing. After modelling the Shutter blades and scratching my head lots to figure out a way to animate it I came up with the following...
I made a block the same height as all my blades then divided the block into equal sections (I.E. 28 Shutter Blades... so 28 Block Divisions).
I aligned the pivot of my Blades to the bottom of each one.
I aligned the block division to the blade pivot locations.
I added Dummies to the Block Division Locations using Attachment Constraints
I Added a position Constraint to each shutter blade, constraining it to its relevant Dummy
I added a look at constraint to each shutter blade, constraining it to look at the above blade.
Then I made my spline/path
I made my block path follow the spline.
All works like a charm... Except when I try to key-frame the animation in the timeline. The blades of the shutter stop moving with the dummies.
Here is a vid that shows whats happening... https://youtu.be/EB8keBSye5w
Any advice on how to fix this???
¡Resuelto! Ir a solución.
