Organizing the Timeline into Seperate Animations
cwymer
cwymer
Hi all,
I'm creating a technical animation which will include a series of small animations including:
- Camera Panning around the scene
- Pipes moving to join together
- Screw Driver tightens screws
- etc....
Is there a way to separate each individual animation and then I can render the Frame sequence for each, for example, Frame 1 - 100 is the camera panning, frame 200 - 300 is the pipes moving together etc...
I control all my animations on the timeline, but it's very messy and I have to use a high number of frames to fit everything in.
What is the best way to 'separate' each animation? I am new to animation software by the way 🙂
I have attached images of my 'Scene sequence' and my current timeline.
Chris
cwymer
Hi all,
Just as an update the best way I found was to separate each scene into 1,000 Frames (assuming a scene is less than 1000 frames).
So each 1,000 frame I start a new scene and render the according frame range for each scene in the render settings, for example: frames 0-250, 1000-14000, 2000-2150 etc.
This enables me to organise each scene and ensure each animation is happening in the correct sequence and the right time 🙂
cwymer
Hi all,
