Never mind, I found a solution!
Using wire parameters works well, as long as you get the math correct. In order to wire the percent of the path deform modifier to the percent of the path constraint controller, it needed to be multiplied by 100 before adding the offset.
for example: ((Percent)*100)+0.85
