Civil View Vehicle Scaling
Gerald.Lockard
Message 1 of 8
Gerald.Lockard
I'm using 3ds and civil view for the first time, and it's a great tool to bring the designers' genio file to life.
However, one problem I am having is when I bring in vehicles and attach them to a string as shown in the tutorials
https://knowledge.autodesk.com/support/3ds-max/getting-started/caas/CloudHelp/cloudhelp/2018/ENU/3DS...
the scale is way off- The cars are maybe 20x what they need to be.
The design info is 1-1metre.
Is there a way I can scale the size of the cars from civil view to suit? I can't see this option anywhere. If not is there a way I can scale the cars then bring them into the civil view library?
Really hope someone can help me with this one!
Replies (7)
Message 2 of 8
Gerald.Lockard
Same issue with signage
Message 3 of 8
tony_niemeyer
If you want to scale in 3ds max the cars need to be grouped and then scaled. Then you can ungroup after your done scaling.
Message 4 of 8
Gerald.Lockard
Thanks for your reply Tony,
Can the cars be scaled and grouped, then imported into civil view?
Civil view is the toolkit I'm using that allows me to add multiple cars at random intervals along the path string to animate the scene.
Message 5 of 8
tony_niemeyer
Are you using vizsim cars? If not you can use the cars in civil view dialog. You can as make costume cars as part of the civil view manager. If you are using vizsim cars and importing those in through civil view you will need to group and scale them after they are imported. I would only do the scaling in max not cad.
Message 6 of 8
tony_niemeyer
Have you tried to use the civil view car replacement tool. To replace your cad cars with the civil view cars?
Message 7 of 8
Gerald.Lockard
Thanks Tony,
My background is design and construct, and this is my first attempt at using civil view to visualise the project.
I was just using the civil view cars in the library. Are you saying I can go into the civil view manager, and then select the civil view cars- edit their scale- then bring them into the scene?
Message 8 of 8
tony_niemeyer
I just sent you a private message with my contact info. Get ahold of me tomorrow and we can go through it. As we do we can make a screen cast and post it. I use civil 3d, 3d studio max and civil view almost every day.
