Forums
Architecture, Engineering & Construction Community Hub
Back
Architecture, Engineering & Construction Hub
See all
Product Design & Manufacturing Community Hub
Back
Product Design & Manufacturing Hub
See all
Media & Entertainment Community Hub
Back
Media & Entertainment Hub
See all
Community Hub
Back
Community Hub
See all
Subscription, Installation & Licensing
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Forums
See all
See all
See all
Community Hub
Community Hub
See all
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Home
3ds Max Forums
3ds Max Animation and Rigging Forum
All community
This section
This board
Knowledge base
Users
Products
Turn on suggestions
Show
only
Search instead for
Welcome to the Autodesk 3ds Max Animation and Rigging Forum. Ask questions, share your knowledge, and make connections.
Autodesk for small business
Design & Make software that works as hard as your business.
Explore today
Activity feed
Communities by language
Ask a question, share your knowledge, or submit a product idea.
Start a topic
Options
Mark all as New
Mark all as Read
Float this item to the top
Subscribe
Bookmark
Subscribe to RSS Feed
Sort by Topic Start Date
All
Trending
Accepted solutions
Unanswered
Most Viewed
Latest
Oldest
New to the 3ds Max Animation and Rigging Forum?
Start Here
Community managers
3ds Max Forums ideas
Share ideas for improving Autodesk products with the team that makes it and submit requests for the features that you would like to see.
Explore ideas
Related tags
"Animation"
(1)
"Ansys Fluent"
(1)
.fbx export
(1)
3 ds max
(1)
3d
(1)
3D Animation
(4)
3D Designe
(1)
3d max
(1)
3dmax
(1)
3ds Max
(10)
3DS max 2021 or 2020
(1)
3ds Max 2022
(2)
3ds max 2024
(1)
3DS Max 2025
(1)
3ds max animation
(3)
3ds max animation to lumion
(1)
3DS MAX INTERACTIVE
(1)
3dsmax
(3)
add bone
(1)
Advanced rigging
(1)
alembic animation materials
(1)
animate
(1)
Animating
(1)
Animation
(62)
Animation & Rigging
(20)
Animation and Rig
(2)
animation blockouts
(1)
Animation Clip
(1)
animation editors
(1)
Animation error
(1)
animation ideea
(1)
Animation Layers
(2)
Animation Problem
(2)
Animation Rendering
(1)
Animations
(2)
Animations export
(1)
Animations Import
(1)
Arnold
(2)
Arnold rendering
(1)
attaching
(1)
Attribute Editor
(1)
auto-orient
(1)
avi
(1)
bake noise animation
(1)
bip
(1)
biped
(9)
biped bug
(1)
biped link
(1)
biped mocap
(1)
BipSlave_Control
(1)
blinking animation
(1)
blobmesh
(1)
blockouts
(1)
Bones
(8)
bug
(2)
bug report
(1)
cam animation
(1)
case
(1)
CAT
(13)
CAT animation
(3)
CAT Crash
(1)
cat rig
(5)
CATIA import
(1)
catrig
(1)
cg
(1)
CGI
(1)
character
(1)
character animation
(1)
character creator
(1)
character rigging
(1)
Clip
(1)
cloth
(5)
collada
(1)
conform binding
(1)
Constrain
(1)
Constraints
(3)
Controller
(2)
controllers
(4)
Copy
(1)
corrupt
(1)
crash
(3)
Crimp Animation
(1)
curve
(1)
curve editor
(1)
cyborg
(3)
DAE
(1)
deflector
(1)
Dope Sheet
(1)
double u joint
(1)
Duplicated Controllers
(1)
Editor
(1)
Error
(1)
escalator steps
(1)
exploded
(1)
Export
(3)
Export 3D model
(2)
Export model
(1)
exporting
(1)
expression controller
(1)
eyelashes aniamtion
(1)
facial animation
(1)
facial rigging
(1)
FBX
(3)
FBX export
(1)
FBX Import
(1)
framerate
(1)
freeze
(1)
Game
(1)
gamemodels
(1)
Geodesic Voxel
(1)
Gimbal Lock
(1)
Grouping
(1)
guns
(1)
Help
(4)
Help & Learning
(1)
Help & Support
(1)
HELP PLEASE!
(1)
Helpers
(1)
hierarchy
(1)
hinges
(1)
iclone 8
(1)
ik
(3)
IK Rigging
(2)
ikfk
(1)
Import
(3)
Inverse Kinematics
(1)
joint
(1)
Keyframes
(1)
keyframes track view
(1)
keys
(1)
Knuckle Joint
(1)
laser
(1)
Layer
(1)
Layer Ranges
(1)
Lighting
(1)
Link
(1)
linkedxform
(1)
Linking
(1)
Load Animation
(1)
Load Pose
(1)
Lug Crimping
(1)
Lumion
(1)
machanic animation
(1)
Mass FX
(3)
MassFX
(5)
math
(1)
Max Script
(1)
maxscript
(1)
mCloth
(2)
Mechanical
(2)
Merge
(1)
Mesh
(1)
Metal wires pressing
(1)
mixamo
(2)
Mocap
(1)
mode
(1)
Modeling
(2)
modifier
(1)
Modifiers
(1)
Morpher
(3)
morpher problem
(1)
morphers
(1)
Motion
(1)
Motion Capture
(1)
Motion Design Tools
(1)
Motion Extraction Node
(1)
Motion Graphic
(1)
motion mixer
(2)
Motion Paths
(1)
MotionMixer
(2)
non Biped
(1)
non-orthogonal
(1)
object properties
(1)
objects misplaced
(1)
Offset
(2)
opaque
(1)
orientation
(1)
particle
(1)
particle flow source
(1)
particleflow
(1)
path
(1)
Path Constraints
(1)
path deform
(1)
Path from Spline
(1)
PathDeform (WSM) modifier
(1)
Pflow
(1)
Physical element
(1)
physics
(1)
physx
(2)
PhysX-Warning
(1)
playblast
(1)
preexisting
(1)
Preview
(1)
Problems
(1)
Project
(1)
props
(1)
ragdoll
(1)
remove
(1)
remove bones
(1)
remove rig
(1)
Remove Shadows
(1)
render
(1)
Rendering
(1)
Rendering animation
(1)
report
(1)
RF
(1)
Rhino
(1)
rig
(3)
Rigging
(38)
Rigging and Animation
(4)
rigging controllers
(1)
Rigging FKIK
(1)
Rigging Help
(3)
rigging programming
(1)
Rigging workflow
(1)
rigidbody
(2)
Rope Wrapping Animation
(1)
rotate
(1)
Rotating Rigged Biped model issue
(1)
rotation
(1)
rotation axis
(1)
Rubik's Cube
(1)
SAE
(1)
SAE Dubai
(2)
save
(1)
Save Pose
(1)
scale
(1)
Scaling
(1)
Scripting
(1)
Setup
(2)
Shadows
(1)
Show Trajectories Toggle
(1)
Sim on render
(1)
Simulation
(1)
Size
(1)
skin
(6)
skin binding
(1)
skin modifier
(2)
skinning
(11)
spline
(2)
Spline IK Solver
(1)
Student
(2)
student project
(2)
substances
(1)
Tank Tracks
(1)
TCB Rotation
(1)
time configuration
(1)
timeline
(2)
Track Rigs
(1)
tracking
(1)
trajectory
(1)
transform animation
(1)
transparent
(2)
turbosmooth
(1)
Twist
(1)
u joint
(1)
unity
(1)
Unreal Engine 4
(1)
USD
(1)
User Interface
(1)
Vertical_Horizontal_Turn
(1)
vertices
(1)
VFX
(2)
View
(1)
Visualization
(1)
vray
(2)
weapons
(1)
Weight property
(1)
weighting
(1)
weights
(2)
wind
(1)
wire parameter rigging
(1)
wire parameters
(3)
wire parameters rigging
(1)
Wires crimp
(1)
Workflow
(1)
wsm
(1)
xref
(1)
Previous
Next
Event
Autodesk Game Developer Series - March 4 and 5, 2026 | Virtual Event
Mar 3, 2026
11:00 PM US/Pacific
See all events
Top contributors
User
Count
MartinBeh
2
View All
Trending topics and solutions
Blog
More Sign-In Options for Autodesk Accounts
Monday, April 6, 2026
See all trending topics and solutions
Related tips and tutorials
Tutorials
Member Spotlight: The creative journey of Solomon W. Jagwe with Flow Studio
Tuesday, March 24, 2026
Read
Bookmark
Tutorials
FumeFX Realtime Foam and Bubbles
Tuesday, September 2, 2025
Read
Bookmark
Tutorials
FumeFX Ocean Simulation and Spectrum
Wednesday, August 27, 2025
Read
Bookmark
See all
