Is it possible to tblsearch only in the current tab? I have a routine that queries the table and if it finds a certain block within a Xref it inserts the appropiate block. The problem is that sometimes I have different XREFs in the same DWG but on seperate tabs.. I'd love to only search the current tab.
as it is right now
(cond
((tblsearch "block" "xref_tblk|8x11")
(setq bl01 "Titleblocks/8.5x11_info.dwg")
);cond - 8.5x11
((tblsearch "block" "Xref_Tblk-8.5x11|8x11")
);cond - 8.5x11-ASI
((tblsearch "block" "xref_tblk|11x17")
(setq bl01 "Titleblocks/11x17_info.dwg")
);cond - 11x17
((tblsearch "block" "xref_tblk-11x17|11x17")
);cond - 11x17-ASI
((tblsearch "block" "xref_tblk|24x36")
(setq bl01 "Titleblocks/24x36_info.dwg")
);cond - 24x36
((tblsearch "block" "xref_tblk|30x42")
(setq bl01 "Titleblocks/30x42_info.dwg")
);cond - 30x42
((tblsearch "block" "xref_tblk|36x48")
(setq bl01 "Titleblocks/36x48_info.dwg")
);cond - 36x48
Solved by Moshe-A. Go to Solution.
hi,
(tblsearch) only searches for a block definition in the block table...to see if a block reference is inserted in layout tab you should use the (ssget) function but (ssget) can not find xref depended block reference so what you should do is loop through layout list and for each layout search for xref reference and if it found? insert the right title block
take a look at this:
(defun insert_title_blocks (/ layout xrefName titleBlockName ss) (setvar "expert" 1) (foreach layout (layoutlist) (setvar "ctab" layout) (vl-some '(lambda (xrefName titleBlockName) (if (setq ss (ssget (list (cons 0 (strcase xrefName))))) (progn (command "._insert" titleBlockName pause pause pause pause ;| here you have to take care of attributes values |;) ;| if they are exist |; (setq ss nil) t ; return true ) ); if ); lambda (list "Xref_Tblk-8.5x11" "xref_tblk-11x17" "xref_tblk-24x36" "xref_tblk-30x42" "xref_tblk-36x48"); xref (list "Titleblocks/8.5x11_info" "Titleblocks/11x17_info" "Titleblocks/24x36_info" "Titleblocks/30x42_info" "Titleblocks/36x48_info"); title blocks ); vl-some ); foreach (setvar "expert" 0) )
i did not test it.
cheers
moshe
