I need to run a lisp command when cad loads. I am able to get it to load and run but I am getting an error(AutoCAD menu utilities loaded.; error: Automation Error. Description was not). The routine is needed to make sure the 2 profiles needed are imported at the start of Autocad. Any help you guys can provide would be awesome.
Below is the lisp
Thank you
Tim
(defun S::Startup ()
(vl-load-com)
(vla-importprofile (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) "PlayworldCAD3D" (strcat "C:\\PSICAD\\Utilities\\" "PlayworldCAD3D.arg") 1)
(vla-importprofile (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) "PlayworldCAD2D" (strcat "C:\\PSICAD\\Utilities\\" "PlayworldCAD2D.arg") 1)
