Visual LISP, AutoLISP and General Customization
Rename Blocks up to a character. Delete text before "_". abcd_123 become 123
5 REPLIES 5
795 Views, 5 Replies
I have 30 blocks per drawing about 60 drawings.  Each block starts with the jobname has other block info and then the block type. For example
Bldg31-MechEquip_ABC
Bldg33-MechText_DEF
Bldg45-ElecEquip_GHI
I want the output to be just ABC, DEF, and GHI.
I have a rename script but I dont know where to go from here.  How can I tell it to remove everything up and including  the "_" symbol?
 Thanks!
5 REPLIES 5
pbejse
Bldg33-MechText_DEF
(defun c:renb (/ i a m p be)
  (while (setq a (tblnext "block" (not a)))
    (if (and
          (not
            (= 4 (logand 4
                 (cdr (assoc 70
                     (tblsearch "BLOCK" (setq m (cdr (assoc 2 a))))
          (setq p (vl-string-position 95 m))
      (command
        "_.rename" "block"
        m
        (if (tblsearch "BLOCK" (setq b (substr m (+ 2 p))))
          (progn
            (setq i 0)
            (while
              (tblsearch "block" (strcat b (itoa (setq i (1+ i)))))
            (strcat b (itoa i))
            ) b
  (princ)
HTH
in reply to: pbejse
Wow,  thanks it works exactly as I need.
What line is it referencing the character "_".  Just out of curiosity, if I wanted to use this script for another application where I wanted to delete everything upto and including a different character like "-" or the series of letters "ab" instead of "_" character, where would I change this in the script.  I was reviewing the code expecting something like "_" that I could just replace with another character if needed but this script is above my understanding.
Kent1Cooper
@Anonymous wrote:
What line is it referencing the character "_".  Just out of curiosity, if I wanted to use ... a different character like "-" or the series of letters "ab" instead of "_" character, where would I change this ....
I don't mean to "steal" the opportunity to reply from pbejse, but here I am with a few minutes....
It's this that's finding the _ character:
That function takes an ASCII character code.  You could do the same with a different function, quoting the actual character [or more than one, e.g. your "ab"]:
(vl-string-search "_" m)
Look into those two functions, plus (ascii) and (char) if you want to find out what the code is for a given character [e.g. your "-"].
Kent Cooper, AIA
pbejse
@Kent1Cooper wrote:
......I don't mean to "steal" the opportunity to reply from pbejse, but here I am with a few minutes....
.... , quoting the actual character [or more than one, e.g. your "ab"]:
(vl-string-search "_" m)...
No offense taken , Your input is always welcome kent.
i agree, vl-string-search it is.
Just out of curiosity, if I wanted to use this script for another application where I wanted to delete everything upto and including a different character like "-" or the series of letters "ab" instead of "_" character, ..
Try this code:
(vl-load-com)
(setq ch (getstring "\nEnter Character(s) to Find: "))
(if (eq ch "")
  (princ "\Invalid character")
    (if (and
          (not
            (= 4 (logand 4
                 (cdr (assoc 70
          (setq p (vl-string-search (strcase ch)(strcase m)))
      (command
        "_.rename" "block" m
        (if (tblsearch "BLOCK" (setq b (substr m (+ 1 (strlen ch) p))))
          (progn
            (setq i 0)
            (while
            (strcat b (itoa i))
            ) b
  (princ)
command: Renb
Enter Character(s) to Find: _
command: Renb
Enter Character(s) to Find: ab
HTH
Kent1Cooper
in reply to: Kent1Cooper
Oops -- make that (chr).
Kent Cooper, AIA
Forma Design Contest
