Thanks Casey.
I replaced the line you gave and it worked as you said - only colors. Is
there a way to add the linetype variable in there?
- Tom C.
"Casey Roberts" wrote in message
news:534AA00E4045EB2B1C2659F5A4C3249A@in.WebX.maYIadrTaRb...
> Actually, the lisp routine had a variable in the wrong spot.... I can send
> the 'fixed' one to you if you like... but it does not retain linetypes...
> only colors.
> If you wanna do it yourself find the line that reads: (third line of the
> actual program):
> "._layer" "_S" "0" "_T" "0" "_c" _conorm "0" "_f" "~0" ""
> and change it to this:
> "._layer" "_S" "0" "_T" "0" "_c" "8" _conorm "_f" "~0" ""
> "Tom C." wrote in message
> news:8B82DC728D594947D5C56E8249F834A3@in.WebX.maYIadrTaRb...
> > Thanks for the link Paul.
> > Unforntunately, I'm using Acad 2000 and the routine gets an error
> somewhere
> > in the first part of setting up the layers. Do you have a version for
> 2000?
> > I'm not too good with lisp and don't know how to tweak the code.
> > Thanks,
> > - Tom C.
> > "Paul Turvill" wrote in message
> > news:BBB807B5F7C7E3EF3AC3F19ECACF5522@in.WebX.maYIadrTaRb...
> > > Try GO-0.LSP from
> > > http://www.turvill.com/t2/free_stuff
> > > It moves everything in a drawing to Layer 0 while retaining all
assigned
> > > colors and linetypes, whether originally set explicitly or bylayer.
> > > ___
> > > news:2E28BF87F29D2A343009A8D0430B980C@in.WebX.maYIadrTaRb...
> > > > Is there a lisp routine that will maintain the linetypes after
you've
> > > > changed the objects to layer 0?
