Delete layout Tab?
15 REPLIES 15
Message 1 of 16
8842 Views, 15 Replies
Delete layout Tab?
hi:
I would like to delete ALL the paper space layout tabs except ModelSpace.
What Lisp or vlisp function can do this?
thanks
15 REPLIES 15
Message 2 of 16
(vla-delete )
"amy" wrote in message
news:805E3C4A43B8C191FCBCA21F5506DD01@in.WebX.maYIadrTaRb...
> hi:
> thanks
Message 3 of 16
amy had this to say
> ModelSpace. What Lisp or vlisp function can do this?
Be aware that you will always have one paperspace layout even if you
delete them all.
(defun delLayouts (/ layouts)
(vl-load-com)
(setq layouts
(vla-get-layouts
(vla-get-activedocument (vlax-get-acad-object))
(mapcar '(lambda (layout)
(vla-delete (vla-item layouts layout))
(layoutlist)
(princ)
There are 10 kinds of people:
Those who understand binary and those who don't
http://www.acadx.com
Message 4 of 16
;; Purpose:
;; Delete layout tabs sepcfied by [Names]
;; Arguments:
;; [Names] - string, name of layout to be deleted
;; wildcard patterns allowed
;; Usage:
;; (DeleteLayouts "Layout1,Layout2")
;; (DeleteLayouts "Layout*")
(defun DeleteLayouts (Names / Layouts Tmp)
(vl-load-com)
(setq
Layouts
(vla-get-layouts
(vlax-get-acad-object))) )
(vlax-for x Layouts
(setq Tmp (strcase (vla-get-name x)))
(if (and (/= "Model" Tmp) (wcmatch Tmp (strcase Names)))
(vla-delete x))
-Jason
Member of the Autodesk Discussion Forum Moderator Program
> hi:
> thanks
Message 5 of 16
Click on the first tab, then hold down the shift key and click on the last tab. This will highlight them all. Now right-click and choose the Delete option. You'll get a message to make sure you know what you'll be doing. Click ok or cancel.
Message 6 of 16
Cliff:
thank you!
Am I missing something?
(defun c:dl ()
(vl-load-com)
(setq acadobj (vlax-get-acad-object))
(setq doc (vla-get-activedocument acadobj))
(setq layouts (vla-get-Layouts doc))
(setq lauoutCnt (vla-get-Count layouts))
(repeat lauoutCnt
(vla-delete layouts)
I am getting an error: Automation Error. Cannot be erased by caller
"Cliff Middleton" wrote in message
news:BFC900D71A72A9F85F7C03B17283F49B@in.WebX.maYIadrTaRb...
> (vla-delete )
> > hi:
ModelSpace.
> > thanks
Message 7 of 16
amy had this to say
In fact, you're not missing anything and that's the problem. The code
you posted will attempt to delete the model tab and that is not allowed.
Message 8 of 16
How about the fact that she is attempting to delete the layout collection,
rather than a layout object?
-Jason
"Frank Oquendo" wrote in message
news:09CD065D8A6985F643815A60B1F6AEF1@in.WebX.maYIadrTaRb...
Message 9 of 16
Jason Piercey had this to say
> collection, rather than a layout object?
That's another possibility. 😉
Message 10 of 16
The layouts variable is a collection of all the layout objects so you must
go through them one by one. The vlax-for function is designed to do that
(works like foreach). Borrowing from Jason's code...
(vlax-for layout Layouts
(if (/= "Model" (vla-get-name x))
(vla-delete x))
I didn't test the code so some tweaking may be required. Or, Frank's will
work just as well. Jason's requires you to supply the list (or rather a
string) of layout names you want deleted. BTW Jason, your Tmp variable will
never equal "Model" since it is always all upper-case.
Cliff
news:FC4ED07CF045163A07585F5DA1698258@in.WebX.maYIadrTaRb...
> Cliff:
> thank you!
> (defun c:dl ()
> (vl-load-com)
> (repeat lauoutCnt
> > (vla-delete )
> > > hi:
> ModelSpace.
> > > thanks
Message 11 of 16
Indeed, thanks Cliff.
> (vla-delete x))
Be sure and change the "x"'s to "layout" also, or layout back to an "x"
-Jason
Message 12 of 16
See, didn't I warn her? Thanks, Jason.
Cliff
Message 13 of 16
I saw the warning 🙂 , just thought I'd point it out anyway.
-Jason
news:77087BBCDA75411D505452F4213CD43A@in.WebX.maYIadrTaRb...
> Cliff
Message 14 of 16
Thak you to all of your reply!
Merry X'mas
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Click
cancel.
Message 15 of 16
-- I don't think that matters.. Model cannot be deleted... or am I wrong?
"Jason Piercey" wrote in message
news:F91542C8AC148C376E6E740D778A4060@in.WebX.maYIadrTaRb...
Message 16 of 16
That is correct, however the code will puke unless you exclude the model tab
or trap the error.
-Jason
Forma Design Contest
