I can't make aliases for custom commands.
So first i made a macro named VEMO in "Cui"
^C^C_LAYER;Set;3031.Vemo's;;_insert;0303VEMO;\;;;_LAYERP
created a button in my ribbon:
Button works fine:
Command: _LAYER Current layer: "4011.Titelhoek" Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: Set Enter layer name to make current or <select object>: 3031.Vemo's Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: Command: _insert Enter block name or [?]: 0303VEMO Units: Centimeters Conversion: 1.0000 Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]: Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: Enter Y scale factor <use X scale factor>: Specify rotation angle <0>: Command: _LAYERP Restored previous layer status.
then i tried to put it in my PGP file:
; This PGP file was created with the AutoCAD Alias Editor. ; Last modified 25/11/2013, 18:39 ; Use the Alias Editor (ALIASEDIT command) to edit this file. ; ; ; Program Parameters File For Autodesk AutoCAD 2014 ; External Command and Command Alias Definitions ; Copyright 2013 Autodesk, Inc. All rights reserved. ; ; Use of this software is subject to the terms of the Autodesk license ; agreement provided at the time of installation or download, or which ; otherwise accompanies this software in either electronic or hard copy form. ; Each time you open a new or existing drawing, AutoCAD searches ; the support path and reads the first acad.pgp file that it finds. ; -- External Commands -- ; While AutoCAD is running, you can invoke other programs or utilities ; such Windows system commands, utilities, and applications. ; You define external commands by specifying a command name to be used ; from the AutoCAD command prompt and an executable command string ; that is passed to the operating system. ; -- Command Aliases -- ; The Command Aliases section of this file provides default settings for ; AutoCAD command shortcuts. Note: It is not recommended that you directly ; modify this section of the PGP file., as any changes you make to this section of the ; file will not migrate successfully if you upgrade your AutoCAD to a ; newer version. Instead, make changes to the new ; User Defined Command Aliases ; section towards the end of this file. ; -- User Defined Command Aliases -- ; You can abbreviate frequently used AutoCAD commands by defining ; aliases for them in the User Defined Command Aliases section of acad.pgp. ; You can create a command alias for any AutoCAD command, ; device driver command, or external command. ; Recommendation: back up this file before editing it. To ensure that ; any changes you make to PGP settings can successfully be migrated ; when you upgrade to the next version of AutoCAD, it is suggested that ; you make any changes to the default settings in the User Defined Command ; Aliases section at the end of this file. ; External command format: ; <Command name>,[<Shell request>],<Bit flag>,[*]<Prompt>, ; The bits of the bit flag have the following meanings: ; Bit 1: if set, don't wait for the application to finish ; Bit 2: if set, run the application minimized ; Bit 4: if set, run the application "hidden" ; Bit 8: if set, put the argument string in quotes ; ; Fill the "bit flag" field with the sum of the desired bits. ; Bits 2 and 4 are mutually exclusive; if both are specified, only ; the 2 bit is used. The most useful values are likely to be 0 ; (start the application and wait for it to finish), 1 (start the ; application and don't wait), 3 (minimize and don't wait), and 5 ; (hide and don't wait). Values of 2 and 4 should normally be avoided, ; as they make AutoCAD unavailable until the application has completed. ; ; Bit 8 allows commands like DEL to work properly with filenames that ; have spaces such as "long filename.dwg". Note that this will interfere ; with passing space delimited lists of file names to these same commands. ; If you prefer multiplefile support to using long file names, turn off ; the "8" bit in those commands. ; Examples of external commands for command windows DEL, DEL, 8,File to delete: , DIR, DIR, 8,File specification: , SH, , 1,*OS Command: , SHELL, , 1,*OS Command: , START, START, 1,*Application to start: , TYPE, TYPE, 8,File to list: , ; Examples of external commands for Windows ; See also the (STARTAPP) AutoLISP function for an alternative method. EXPLORER, START EXPLORER, 1,, NOTEPAD, START NOTEPAD, 1,*File to edit: , PBRUSH, START PBRUSH, 1,, ; Command alias format: ; <Alias>,*<Full command name> ; The following are guidelines for creating new command aliases. ; 1. An alias should reduce a command by at least two characters. ; Commands with a control key equivalent, status bar button, ; or function key do not require a command alias. ; Examples: Control N, O, P, and S for New, Open, Print, Save. ; 2. Try the first character of the command, then try the first two, ; then the first three. ; 3. Once an alias is defined, add suffixes for related aliases: ; Examples: R for Redraw, RA for Redrawall, L for Line, LT for ; Linetype. ; 4. Use a hyphen to differentiate between command line and dialog ; box commands. ; Example: B for Block, -B for -Block. ; ; Exceptions to the rules include AA for Area, T for Mtext, X for Explode. ; -- Sample aliases for AutoCAD commands -- ; These examples include most frequently used commands. NOTE: It is recommended ; that you not make any changes to this section of the PGP file to ensure the ; proper migration of your customizations when you upgrade to the next version of ; AutoCAD. The aliases listed in this section are repeated in the User Custom ; Settings section at the end of this file, which can safely be edited while ; ensuring your changes will successfully migrate. 3A, *3DARRAY 3DMIRROR, *MIRROR3D 3DNavigate,*3DWALK 3DO, *3DORBIT 3DP, *3DPRINT 3DPLOT, *3DPRINT 3DW, *3DWALK 3F, *3DFACE 3M, *3DMOVE 3P, *3DPOLY 3R, *3DROTATE 3S, *3DSCALE A, *ARC AC, *BACTION ADC, *ADCENTER AECTOACAD, *-ExportToAutoCAD AA, *AREA AL, *ALIGN 3AL, *3DALIGN AP, *APPLOAD APLAY, *ALLPLAY AR, *ARRAY -AR, *-ARRAY ARR, *ACTRECORD ARM, *ACTUSERMESSAGE -ARM, *-ACTUSERMESSAGE ARU, *ACTUSERINPUT ARS, *ACTSTOP -ARS, *-ACTSTOP ATI, *ATTIPEDIT ATT, *ATTDEF -ATT, *-ATTDEF ATE, *ATTEDIT -ATE, *-ATTEDIT ATTE, *-ATTEDIT B, *BLOCK -B, *-BLOCK BC, *BCLOSE BE, *BEDIT BH, *HATCH BLENDSRF, *SURFBLEND BO, *BOUNDARY -BO, *-BOUNDARY BR, *BREAK BS, *BSAVE BVS, *BVSTATE C, *CIRCLE CAM, *CAMERA CBAR, *CONSTRAINTBAR CH, *PROPERTIES -CH, *CHANGE CHA, *CHAMFER CHK, *CHECKSTANDARDS CLI, *COMMANDLINE COL, *COLOR COLOUR, *COLOR CO, *COPY CONVTOMESH, *MESHSMOOTH CP, *COPY CPARAM, *BCPARAMETER CREASE, *MESHCREASE CREATESOLID, *SURFSCULPT CSETTINGS, *CONSTRAINTSETTINGS CT, *CTABLESTYLE CUBE, *NAVVCUBE CURVATUREANALYSIS, *ANALYSISCURVATURE CYL, *CYLINDER D, *DIMSTYLE DAL, *DIMALIGNED DAN, *DIMANGULAR DAR, *DIMARC DELETE, *ERASE JOG, *DIMJOGGED DBA, *DIMBASELINE DBC, *DBCONNECT DC, *ADCENTER DCE, *DIMCENTER DCENTER, *ADCENTER DCO, *DIMCONTINUE DCON, *DIMCONSTRAINT DDA, *DIMDISASSOCIATE DDI, *DIMDIAMETER DED, *DIMEDIT DELCON, *DELCONSTRAINT DI, *DIST DIV, *DIVIDE DJL, *DIMJOGLINE DJO, *DIMJOGGED DL, *DATALINK DLI, *DIMLINEAR DLU, *DATALINKUPDATE DO, *DONUT DOR, *DIMORDINATE DOV, *DIMOVERRIDE DR, *DRAWORDER DRA, *DIMRADIUS DRAFTANGLEANALYSIS, *ANALYSISDRAFTANGLE DRE, *DIMREASSOCIATE DRM, *DRAWINGRECOVERY DS, *DSETTINGS DST, *DIMSTYLE DT, *TEXT DV, *DVIEW DX, *DATAEXTRACTION E, *ERASE ED, *DDEDIT EL, *ELLIPSE ER, *EXTERNALREFERENCES ESHOT, *EDITSHOT EX, *EXTEND EXIT, *QUIT EXP, *EXPORT EXT, *EXTRUDE EXTENDSRF, *SURFEXTEND F, *FILLET FI, *FILTER FILLETSRF, *SURFFILLET FREEPOINT, *POINTLIGHT FSHOT, *FLATSHOT G, *GROUP -G, *-GROUP GCON, *GEOMCONSTRAINT GD, *GRADIENT GENERATESECTION, *SECTIONPLANETOBLOCK GEO, *GEOGRAPHICLOCATION GR, *DDGRIPS H, *HATCH -H, *-HATCH HE, *HATCHEDIT HB, *HATCHTOBACK HI, *HIDE I, *INSERT -I, *-INSERT IAD, *IMAGEADJUST IAT, *IMAGEATTACH ICL, *IMAGECLIP IM, *IMAGE -IM, *-IMAGE IMP, *IMPORT IN, *INTERSECT INSERTCONTROLPOINT, *CVADD INF, *INTERFERE IO, *INSERTOBJ ISOLATE, *ISOLATEOBJECTS QVD, *QVDRAWING QVDC, *QVDRAWINGCLOSE QVL, *QVLAYOUT QVLC, *QVLAYOUTCLOSE J, *JOIN JOGSECTION, *SECTIONPLANEJOG L, *LINE LA, *LAYER -LA, *-LAYER LAS, *LAYERSTATE LE, *QLEADER LEN, *LENGTHEN LESS, *MESHSMOOTHLESS LI, *LIST LINEWEIGHT, *LWEIGHT LMAN, *LAYERSTATE LO, *-LAYOUT LS, *LIST LT, *LINETYPE -LT, *-LINETYPE LTYPE, *LINETYPE -LTYPE, *-LINETYPE LTS, *LTSCALE LW, *LWEIGHT M, *MOVE MA, *MATCHPROP MAT, *MATBROWSEROPEN ME, *MEASURE MEA, *MEASUREGEOM MI, *MIRROR ML, *MLINE MLA, *MLEADERALIGN MLC, *MLEADERCOLLECT MLD, *MLEADER MLE, *MLEADEREDIT MLS, *MLEADERSTYLE MO, *PROPERTIES MORE, *MESHSMOOTHMORE MOTION, *NAVSMOTION MOTIONCLS, *NAVSMOTIONCLOSE MS, *MSPACE MSM, *MARKUP MT, *MTEXT MV, *MVIEW NETWORKSRF,*SURFNETWORK NORTH, *GEOGRAPHICLOCATION NORTHDIR, *GEOGRAPHICLOCATION NSHOT, *NEWSHOT NVIEW, *NEWVIEW O, *OFFSET OFFSETSRF, *SURFOFFSET OP, *OPTIONS ORBIT, *3DORBIT OS, *OSNAP -OS, *-OSNAP P, *PAN -P, *-PAN PA, *PASTESPEC RAPIDPROTOTYPE, *3DPRINT PAR, *PARAMETERS -PAR, *-PARAMETERS PARAM, *BPARAMETER PARTIALOPEN, *-PARTIALOPEN PATCH, *SURFPATCH PC, *POINTCLOUD PCATTACH, *POINTCLOUDATTACH PCINDEX, *POINTCLOUDINDEX PE, *PEDIT PL, *PLINE PO, *POINT POFF, *HIDEPALETTES POINTON, *CVSHOW POINTOFF, *CVHIDE POL, *POLYGON PON, *SHOWPALETTES PR, *PROPERTIES PRCLOSE, *PROPERTIESCLOSE PROPS, *PROPERTIES PRE, *PREVIEW PRINT, *PLOT PS, *PSPACE PSOLID, *POLYSOLID PTW, *PUBLISHTOWEB PU, *PURGE -PU, *-PURGE PYR, *PYRAMID QC, *QUICKCALC QCUI, *QUICKCUI QP, *QUICKPROPERTIES RED, *REDRAW RA, *REDRAWALL RC, *RENDERCROP RE, *REGEN REA, *REGENALL REBUILD, *CVREBUILD REC, *RECTANG REFINE, *MESHREFINE REG, *REGION REMOVECONTROLPOINT, *CVREMOVE REN, *RENAME -REN, *-RENAME REV, *REVOLVE R, *ROTATE RP, *RENDERPRESETS RPR, *RPREF RR, *RENDER RW, *RENDERWIN S, *STRETCH SC, *SCALE SCR, *SCRIPT SE, *DSETTINGS SEC, *SECTION SET, *SETVAR SHA, *SHADEMODE SL, *SLICE SMOOTH, *MESHSMOOTH SN, *SNAP SO, *SOLID SP, *SPELL SPL, *SPLINE SPLANE, *SECTIONPLANE SPLAY, *SEQUENCEPLAY SPLIT, *MESHSPLIT SPE, *SPLINEDIT SSM, *SHEETSET ST, *STYLE STA, *STANDARDS SU, *SUBTRACT T, *MTEXT -T, *-MTEXT TA, *TABLET TB, *TABLE TEDIT, *TEXTEDIT TH, *THICKNESS TI, *TILEMODE TO, *TOOLBAR TOL, *TOLERANCE TOR, *TORUS TP, *TOOLPALETTES TR, *TRIM TS, *TABLESTYLE UC, *UCSMAN UN, *UNITS -UN, *-UNITS UNCREASE, *MESHUNCREASE UNHIDE, *UNISOLATEOBJECTS UNI, *UNION UNISOLATE, *UNISOLATEOBJECTS V, *VIEW VGO, *VIEWGO VPLAY, *VIEWPLAY -V, *-VIEW VP, *DDVPOINT -VP, *VPOINT VS, *VSCURRENT VSM, *VISUALSTYLES -VSM, *-VISUALSTYLES W, *WBLOCK -W, *-WBLOCK WE, *WEDGE WHEEL, *NAVSWHEEL X, *EXPLODE XA, *XATTACH XB, *XBIND -XB, *-XBIND XC, *XCLIP XL, *XLINE XR, *XREF -XR, *-XREF Z, *ZOOM ZEBRA, *ANALYSISZEBRA ; The following are alternative aliases and aliases as supplied ; in AutoCAD Release 13. AV, *DSVIEWER CP, *COPY DIMALI, *DIMALIGNED DIMANG, *DIMANGULAR DIMBASE, *DIMBASELINE DIMCONT, *DIMCONTINUE DIMDIA, *DIMDIAMETER DIMED, *DIMEDIT DIMTED, *DIMTEDIT DIMLIN, *DIMLINEAR DIMORD, *DIMORDINATE DIMRAD, *DIMRADIUS DIMSTY, *DIMSTYLE DIMOVER, *DIMOVERRIDE LEAD, *LEADER TM, *TILEMODE ; Aliases for Hyperlink/URL Release 14 compatibility SAVEURL, *SAVE OPENURL, *OPEN INSERTURL, *INSERT ; Aliases for commands discontinued in AutoCAD 2000: AAD, *DBCONNECT AEX, *DBCONNECT ALI, *DBCONNECT ASQ, *DBCONNECT ARO, *DBCONNECT ASE, *DBCONNECT DDATTDEF, *ATTDEF DDATTEXT, *ATTEXT DDCHPROP, *PROPERTIES DDCOLOR, *COLOR DDLMODES, *LAYER DDLTYPE, *LINETYPE DDMODIFY, *PROPERTIES DDOSNAP, *OSNAP DDUCS, *UCS ; Aliases for commands discontinued in AutoCAD 2004: ACADBLOCKDIALOG, *BLOCK ACADWBLOCKDIALOG, *WBLOCK ADCENTER, *ADCENTER BMAKE, *BLOCK BMOD, *BLOCK BPOLY, *BOUNDARY CONTENT, *ADCENTER DDATTE, *ATTEDIT DDIM, *DIMSTYLE DDINSERT, *INSERT DDPLOTSTAMP, *PLOTSTAMP DDRMODES, *DSETTINGS DDSTYLE, *STYLE DDUCS, *UCSMAN DDUCSP, *UCSMAN DDUNITS, *UNITS DDVIEW, *VIEW DIMHORIZONTAL, *DIMLINEAR DIMROTATED, *DIMLINEAR DIMVERTICAL, *DIMLINEAR DOUGHNUT, *DONUT DTEXT, *TEXT DWFOUT, *PLOT DXFIN, *OPEN DXFOUT, *SAVEAS PAINTER, *MATCHPROP PREFERENCES, *OPTIONS RECTANGLE, *RECTANG SHADE, *SHADEMODE VIEWPORTS, *VPORTS EDWFX, *EXPORTDWFX EDWF, *EXPORTDWF EPDF, *EXPORTPDF -QPUB, *-EXPORT ; Aliases for commands discontinued in AutoCAD 2007: RMAT, *MATBROWSEROPEN FOG, *RENDERENVIRONMENT FINISH, *MATERIALS SETUV, *MATERIALMAP SHOWMAT, *LIST RFILEOPT, *RENDERPRESETS RENDSCR, *RENDERWIN ; Aliases for commands discontinued in AutoCAD 2009: DASHBOARD, *RIBBON DASHBOARDCLOSE, *RIBBONCLOSE ; Aliases for sysvars discontinued in AutoCAD 2013: RASTERPREVIEW, *THUMBSAVE AUTOCOMPLETE, *-INPUTSEARCHOPTIONS AUTOCOMPLETEMODE, *-INPUTSEARCHOPTIONS AUTOCOMPLETEDELAY, *INPUTSEARCHDELAY ; -- User Defined Command Aliases -- ; Make any changes or additions to the default AutoCAD command aliases in ; this section to ensure successful migration of these settings when you ; upgrade to the next version of AutoCAD. If a command alias appears more ; than once in this file, items in the User Defined Command Alias take ; precedence over duplicates that appear earlier in the file. ; **********----------********** ; No xlate ; DO NOT REMOVE VEMO,*VEMO 41, *401K 42, *402H 12, *cirkel 303V, *303V 309O, *309O
and after a reinit i discover i doesn't work. i did some research about Lisp (first time) and i found out that you can make commands with Lisp to.
So i made a Txt file with the contents:
(DEFUN C:VEMO () (COMMAND "VEMO"))
in my personal file. C:\Program Files\Autodesk\AutoCAD 2014\Support\en-us (file: Commands.lisp)
But when i load the lisp in "load application". and restart autocad it doesn work:
So i must doing something wrong in all those steps? i m very new to lisp etc. so a good explaining is needed 🙂 when giving solutions or questions.
Shout away
PS: already been to
but i m doing it prob wrong or something like that
Solved by Kent1Cooper. Go to Solution.
If VEMO is just a name assigned to a button that contains a macro routine, I don't think that qualifies it as a defined command that can be called up by any means other than that button. The AutoLISP (command) function can only use actual AutoCAD command names, not User-defined commands. Your (defun) definition of VEMO can't call the same command name [although it is possible to do something similar to that if you re-define an AutoCAD command name after Undefining it, such as (for example) to include forcing it to set a certain Layer current when drawing a certain type of entity, but that's another topic].
I would go about it this way:
Make a file called VEMO.lsp [not .txt], to do what the macro does, but in LISP terminology, something like this [untested]:
(defun C:VEMO ()
(command
"_.LAYER" "_Set" "3031.Vemo's" ""
"_.insert" "0303VEMO" pause "" "" ""
"_.LAYERP"
); command
); defun
In your acaddoc.lsp file, put something in to make that command name available:
(load "VEMO")
or, if you want it to not load it unless and until the User calls for the command:
(autoload "VEMO" '("VEMO"))
Then it will be available without the need for an alias in the .pgp file [besides, there's not much point in using an alias that's the same as the full command name], and the contents of the button in the ribbon can be just:
^C^CVEMO
or if that doesn't work [I don't have any buttons quite analagous to that situation], it may need to be this way, as would be required to call a User-defined command within another LISP routine:
^C^C(C:VEMO)
@Anonymous wrote:
Kent,
it works!
can you make the lisp repeat himself?
Thanks!
Lucked out on that one....
You can build repeating in, something like this:
(defun C:VEMO (/ inspt)
(command "_.LAYER" "_Set" "3031.Vemo's" "")
(while (setq inspt (getpoint "\nInsertion point: "))
(command
"_.insert" "0303VEMO" inspt "" "" ""
); command
); while
(command "_.layerp")
); defun
However, that won't let you see the Block dragging as you go for the insertion point. There are several [untested] ways you could have it do that, the simplest but crudest of which is to require the User to hit Escape when they don't want to insert any more:
(defun C:VEMO (/ *error*)
(defun *error* ()
); defun -- *error*
(while T
(command "_.insert" "0303VEMO" pause "" "" "")
); while
); defun
But it can be more sophisticated, for instance allowing Enter or space or Escape to end it:
(defun C:VEMO (/ *error* inspt done)
(defun *error* (); on Escape at insertion-point prompt
); defun -- *error*
(while (not done)
(command "_.insert" "0303VEMO"); leave in command
(cond ; at insertion-point prompt
((setq inspt (getpoint "\nInsertion point or <exit>: )); point if picked, nil if Enter
(command inspt "" "" ""); finish Insertion
); end picked-a-point condition
(T ; on Enter/space at insertion-point prompt
(command); cancel Insert
(setq done T); stop (while) loop
); end exit condition
); cond
); while
); defun
@Anonymous wrote:
the third one doesn't work. ....
That's probably because I seem to have omitted the closing double-quote in the prompt:
((setq inspt (getpoint "\nInsertion point or <exit>: ")); point if picked, nil if Enter
It works for me here with that correction, though not quite as I expected [Escape doesn't exit it cleanly, and it doesn't show the Block dragging] -- I'll have to think about that....
EDIT:
Escape exits cleanly if you add a (command) with no arguments, to cancel the Insert command, [further Edit: and a message argument, even though it's not used] in the error handler:
(defun *error* (errmsg); on Escape at insertion-point prompt
(command); cancel Insert command, then
); defun -- *error*
(defun C:VEMO (/ *error* inspt done) (defun *error* (errmsg); on Escape at insertion-point prompt (command); cancel Insert command, then (command "_.layerp") ); defun -- *error* (command "_.LAYER" "_Set" "3031.Vemo's" "") (while (not done) (command "_.insert" "0303VEMO"); leave in command (cond ; at insertion-point prompt ((setq inspt (getpoint "\nInsertion point or <exit>: ")); point if picked, nil if Enter (command inspt "" "" ""); finish Insertion ); end picked-a-point condition (T ; on Enter/space at insertion-point prompt (command); cancel Insert (setq done T); stop (while) loop ); end exit condition ); cond ); while (command "_.layerp") ); defun
so that's what i have for some other followers (last edit). Works for me, did also the first edit, with the wrong excape exit, i got a scalefunction then. Nicely done kent! that thing will help me a lot. thanks!
@Anonymous wrote:
.... Nicely done kent! that thing will help me a lot. thanks!
You're welcome, and thank you for racking up three Solutions-authored for me on one thread! [Gotta keep my count up, so they'll keep me on as an Expert Elite, after all.]
